Two Rock Classic Reverb Signature Schematic (Current Version)
Eges
Post by Eges »
Hello guys, anyone has got the schematic of the current production line of the amp? (With gain structure switch)
Eges
Re: Two Rock Classic Reverb Signature Schematic (Current Version)
Post by Eges »
Pardon my amazing paint editing. Is this too far off from the real thing? This is the only thing I can come up with searching the whole forum. (Only the preamp section is shown on the schematic)
GAStan
Post by GAStan »
I don't know anything about Two Rock amps. Have you asked Two Rock for a schematic?
The schematic you posted looks very similar to a ODS Low Plate Clean section. Look at the #124 schematic and you should see the similarities.
Glenn
I solder better than I play.
Eges
Post by Eges »
GAStan wrote: Tue Mar 26, 2024 8:20 pm I don't know anything about Two Rock amps. Have you asked Two Rock for a schematic?
I think they probably won’t want to share it. I based it off the one that forum members figured out as Two Rock Bloomfield Drive, whichs cleans sound pretty identical in demos when gain toggle is on 80k. So that was my best guess
Aaron
Post by Aaron »
Eges wrote: Sat Mar 16, 2024 9:38 am Hello guys, anyone has got the schematic of the current production line of the amp? (With gain structure switch)
Post a gut shot if you have one. Shouldn't be too hard to trace.
Eges
Post by Eges »
Aaron wrote: Wed Mar 27, 2024 2:22 am
This is what we have as far as I know, thank you for helping! EDIT: Found more shots of Classic Reverb Signature.
Eges
Post by Eges »
And I've found Studio Signature's detailed guts which is supposed to be 35 watt version of the amp(minus rock jazz switch, tonestack bypass and fet). Don't know if it is true or not but this one can probably help too.
Aaron
Post by Aaron »
I’m on a plane for 9 hours on Monday. So tracing this will give something to do.
Eges
Post by Eges »
Thank you so much! Would be really helpful
Guy77
Post by Guy77 »
Eges wrote: Wed Mar 27, 2024 6:54 am And I've found Studio Signature's detailed guts which is supposed to be 35 watt version of the amp(minus rock jazz switch, tonestack bypass and fet). Don't know if it is true or not but this one can probably help too.
The mixing tube wiring on this Studio signature looks a little different than the "Classic" and I don't see the 68k resistor going from V1b to V2a, although the tubes are criss-crossing on the chassis so they could have sneaked it in.
Cheers
Guy
rccolgan
Post by rccolgan »
CRS v3 built in 2011 s/n 44. Someone posted this on the two rock Facebook fan page last night. Hope this helps some.
Ryan
https://www.thetonegeek.com/
Eges
Post by Eges »
rccolgan wrote: Thu Apr 04, 2024 9:23 am CRS v3 built in 2011 s/n 44. Someone posted this on the two rock Facebook fan page last night. Hope this helps some.
Isn't this the Custom Reverb Sig? I'm mostly curious about Classic Reverb Sig
rccolgan
Post by rccolgan »
Oooo yes it is the custom. CRS vs CRS 😬 my mistake
Ryan
andyhardy
Post by andyhardy »
Fun times
rccolgan
Post by rccolgan »
Deleted. Accidentally replied to a deleted comment.. I think?
Ryan
