Bright cap on Blues Junior?
Fender Amp Discussion
Post by Mark »
I was working on a mate’s version 3 Blues Junior and I wondered why one of the mods on them isn’t to put the 100pF bright cap on a switch?
The other thing I was wondering about was the 10K grid stopper resistors, I’ve heard they are there to stop RF etc getting into the amp, but I was wondering if increasing the valve from 10K to 220K or 470K bypassed with a 470pF cap might minimise blocking distortion?
As shown in the first picture the circled 130K resistor is there to stop the amp going into low frequency oscillation when volume, master and bass controls are dimed.
I put the 2.7K cathode resistor in for some Marshall goodness, I have found there is slightly less output (audibly heard) and the distortion is slightly different. If I didn’t have it on a switch I wouldn’t have noticed it.
I have noticed that Fromel have an interesting replacement valve board. I mentioned it as it uses a 12DW7 in lieu of a 12AX7 to use a cathode follower powering the tone controls, it allows the output stage to be made cathode bias which may or not be a good thing, the heaters are elevated via the cathode resistor of the output stage I assume.
Any thoughts?
Stevem
Re: Bright cap on Blues Junior?
Post by Stevem »
You could do that which is like a bright switch on a BF and SF Fender, but when it’s wired that way as the volume get opened up more and more to 50% the bright effect is reduced until after 50% point it does not take place at all.
If your ok with that then have at it.
Post by Mark »
Stevem wrote: Thu Feb 20, 2025 10:14 am You could do that which is like a bright switch on a BF and SF Fender, but when it’s wired that way as the volume get opened up more and more to 50% the bright effect is reduced until after 50% point it does not take place at all.
I typically wouldn’t use the bright switch on a Fender amp unless I had a particularly dull sounding guitar. That’s what prompted me to mention it.
Post by Mark »
I end up using a three way switch with the 100pF and 250pF value. I liked it.
stratomaster
Post by stratomaster »
There's also a "dull" cap at the end of the preamp right before the master volume. I tend to pull both out and replace them with a plate bypass cap on the final stage of about 680pF. Gives a more natural high end in my opinion.
Post by Mark »
stratomaster wrote: Wed Apr 30, 2025 3:22 am There's also a "dull" cap at the end of the preamp right before the master volume. I tend to pull both out and replace them with a plate bypass cap on the final stage of about 680pF. Gives a more natural high end in my opinion.
Thanks for your comment, the dull cap wasn’t in the amp. It may have been removed in a previous mod.
The 250pF cap sounds well suited to funk tones on a Strat using the 2 & 4 positions.
