Synergy SYN-2 Rack Mount Preamp power transformer spec
Hello, guys. Is someone has Synergy SYN-2 Rack Mount Preamp power transformer spec ? Thanks
Re: Synergy SYN-2 Rack Mount Preamp power transformer spec
I’am sure Synergy does. How about shooting them a email?
Actually if this unit is only 1 rack space tall I would be surprised if it had no power transformer, but a switching type power supply.
Thanks for your reply.
They use Toroidal Transformer.
I have been happy with the Antek toriodal transformers. The 50VA units (at least the ones I have used will fit into a 1U chassis, just barely) Something like this; https://www.antekinc.com/as-05t200-50va ... ansformer/
The pic below is from a 6G15 reverb that I built into a standard Fender chassis & mounted all the transformers internally to keep them away from the reverb tank. Very quiet.
