What Exactly Happens When You Pull Two Output Tubes On the Same Side In A Plexi ?
Marshall Amp Discussion
Cathode Ray
Post by Cathode Ray »
Asking based on two things I've experienced.. first was a guy who went by VHoholic on the old MetroAmp forum who used to run a Marshall 1959 circuit with only one 6CA7 output tube installed, and more recently Jim Gaustad has said he runs his custom-built EVH spec amp with V4 &V5 pulled.
I've always pulled either the two inner or out tubes to cut power down to 50W, but always been told never to pull tubes from the same side.
These guys claim this works with no harm to the amp - running them this way for decades.
maxkracht
Re: What Exactly Happens When You Pull Two Output Tubes On the Same Side In A Plexi ?
Post by maxkracht »
What happens: less power, more distortion (not the kind you want), more hum, greater risk of damaging your output transformer, potentially risk damaging other tubes with higher voltages. This is assuming the tubes on the same side are in parallel, you don't need to wire it in the normal fashion where one side is push and the other pull, you could have the tubes staggered.
Cathode Ray
maxkracht wrote: Sun May 18, 2025 10:51 pm What happens: less power, more distortion (not the kind you want), more hum, greater risk of damaging your output transformer, potentially risk damaging other tubes with higher voltages. This is assuming the tubes on the same side are in parallel, you don't need to wire it in the normal fashion where one side is push and the other pull, you could have the tubes staggered.
Yeah, so the scenario here would be a standard circuit - off-the-shelf 68 Super Lead, so to speak.
Jim Gaustad was saying doing this turns the amp into "pull" rather than a "push/pull".
maxkracht
Post by maxkracht »
If you want a SE amp, probably wise to use a SE transformer. They are made differently. You might get away with running a PP transformer sorta like a SE, but I doubt it sounds very good and the the transformer probably isn't happy.
Cathode Ray
maxkracht wrote: Mon May 19, 2025 1:09 am.. I doubt it sounds very good ..
You guys tell me.
:lol:
I tried pulling two tubes from the same side of a 100W 4x 6L6 power amp sim. Plate dissipation went from 21.8 (72%) to 36.8W (123%) per tube, with a whole lot of second harmonic distortion. I guess if you halve the life on half the number of tubes you would break even.
Helmholtz
Post by Helmholtz »
martin manning wrote: Mon May 19, 2025 10:08 pm Plate dissipation went from 21.8 (72%) to 36.8W (123%) per tube..
Interesting.
I assume this is not at idle?
Roe
Post by Roe »
martin manning wrote: Mon May 19, 2025 10:08 pm I tried pulling two tubes from the same side of a 100W 4x 6L6 power amp sim. Plate dissipation went from 21.8 (72%) to 36.8W (123%) per tube, with a whole lot of second harmonic distortion. I guess if you halve the life on half the number of tubes you would break even.
do you get any of this effect if the phase inverter is greatly unbalanced, driving one side way harder than another?
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
Helmholtz wrote: Mon May 19, 2025 11:08 pm
Interesting.
I have input sine amplitude set to produce 100W output into a resistive load, then just remove the two tubes on one side and rerun.
Roe wrote: Tue May 20, 2025 7:27 am do you get any of this effect if the phase inverter is greatly unbalanced, driving one side way harder than another?
Not sure how this would be relevant given that one side is open circuit. It would just be more or less signal being applied to the working side, no?
Helmholtz
Post by Helmholtz »
martin manning wrote: Tue May 20, 2025 11:43 am I have input sine amplitude set to produce 100W output into a resistive load, then just remove the two tubes on one side and rerun.
Thanks.
I'm surprized by the huge increase in PD.
Grid signal, bias and plate load should essentially be the same.
Leaves less plate and screen voltage sag, but I didn't epect that much difference.
Roe
Post by Roe »
martin manning wrote: Tue May 20, 2025 11:52 am
No, I was thinking of a case where all output tubes are operational but the driver is greatly imbalanced. I've seen quite few cases of redplating on v4-v5 on 100w marshalls (without any redplating on v6-v7)
4x12" w/H75s
Purgasound
Post by Purgasound »
I can't see where this would have any good outcome. A 100W EL34 based transformer has a winding ratio to suit around a 1.7K primary impedance. Dropping two tubes creates a mismatch since two EL34's want to see a winding ratio suited for a 3.4K primary. That alone turns your 8 ohm tap into your 16 ohm tap, your 4 into 8, etc. When driving a load that's 2x higher than intended the current flow across the voice coil will be halved. That's going to come with other side effects as well.
When one side push/pull amplifier is at its peak current flow the other side will shut off so I can't imagine an incomplete waveform would be pleasing to the ears. I suppose with high levels of crossover and squarewave distortion it may shorten the gaps.
Whatever the desired goal is for tone, I'm sure there is a better way to get there. Of course nothing is wrong with experimentation but this isn't an avenue I would be interested in pursuing personally.
Cheers.
Roe
Post by Roe »
Purgasound wrote: Fri May 23, 2025 6:02 am I can't see where this would have any good outcome. A 100W EL34 based transformer has a winding ratio to suit around a 1.7K primary impedance. Dropping two tubes creates a mismatch since two EL34's want to see a winding ratio suited for a 3.4K primary. That alone turns your 8 ohm tap into your 16 ohm tap, your 4 into 8, etc. When driving a load that's 2x higher than intended the current flow across the voice coil will be halved. That's going to come with other side effects as well.
Cheers.
how about 4 el34s with a very unmatched driver that redplates v4-v5, but not v6-v7 (a common scenario)
4x12" w/H75s
Purgasound
Roe wrote: Fri May 23, 2025 6:12 am how about 4 el34s with a very unmatched driver that redplates v4-v5, but not v6-v7 (a common scenario)
I'm not sure what you're getting at.
Yes, in a Superlead circuit V4 and V5 draw double the current as V6 and V7 when the power amp is driven into full distortion. The red plating is a sign something needs adjusting. If the amp is going to be driven that hard it's a good idea to increase the screen grid resistors to 2.2K and increase negative voltage for the bias. That should take care of any redplating. Cement wirewound for those resistors too. Those old shiny1K green ones and the black metal oxide ones can start to crack open when they get super hot.
