Taming the brightness
Matthews Guitars
Post by Matthews Guitars »
I've observed that my Express clone is quite a bright sounding amp. I run low treble settings, don't use the bright switch, and presence is usually at zero, and I still use the tone control of the guitar to trim the high frequencies so the feedback is just right and not killing eardrums.
I could experiment but I'd rather ask the veterans. What's the preferred way to tame that excessive brightness without compromising the soul of the Express circuit?
Yes, I have a variety of speakers and cabinet combinations to choose from. And some I have to avoid with this amp. My darkest sounding cabinets are the best balances, such as my 4x12 full of EVM-12Ls, and yes, those ARE relatively dark speakers compared to some.
Roe
Re: Taming the brightness
Post by Roe »
try a high-capacitance cable from the guitar, turn up the volume a bit and consider a warmer bias on the el34s. turning up the bass may also help as well as turning down mids and treble a bit
Matthews Guitars
This kind of brightness is beyond mere control adjustments to handle. Looking for suggestions on taming it by adjusting certain component values or adding a treble bleed at just the right spot in the circuit.
Yes it warms up at higher volume but even then it's still pretty bright. Loud and bright is a bad combination for my ears.
Roe
Post by Roe »
Matthews Guitars wrote: ↑Tue Jul 01, 2025 2:43 am This kind of brightness is beyond mere control adjustments to handle. Looking for suggestions on taming it by adjusting certain component values or adding a treble bleed at just the right spot in the circuit.
start with the guitar cable, get a curly coil or a similar hi-capactance cable. these amp were designed before low-capacitance cables became widespread
Matthews Guitars
Respectfully, that's two people who suggested curly cables and that's not the fix I'm after. If you don't have a component related suggestion to make, within the amp chassis, then you're not making the suggestions I will consider implementing.
Colossal
Post by Colossal »
You can try increasing the 50p across the PI plate load resistors (the so-called fizz cap) to 250p. You will hear that as a high cut.
Roe
Post by Roe »
Matthews Guitars wrote: ↑Tue Jul 01, 2025 11:57 pm Respectfully, that's two people who suggested curly cables and that's not the fix I'm after. If you don't have a component related suggestion to make, within the amp chassis, then you're not making the suggestions I will consider implementing.
so you are not willing to try it? Consider a 470pf snubber then from the grid of the first gainstage to ground or the cathode
What about a larger grid stopper on the input stage? That will accomplish about the same thing as a high-capacitance instrument cable.
Roe
Post by Roe »
martin manning wrote: ↑Wed Jul 02, 2025 2:19 am What about a larger grid stopper on the input stage? That will accomplish about the same thing as a high-capacitance instrument cable.
yes but it adds resistive hiss. try a 470k-1m grid resistor on v2 instead?
Matthews Guitars
Yes, I'll give that a try.
I don't want the "fix" to be something external to the amp. If I make another one like this and sell it to somebody, the last thing I want to do is tell him to find and buy a specific kind of instrument cable to get his desired tone.
I guess I'm going to have to experiment with treble bleed caps to ground at certain points in the circuit, at various values.
wpaulvogel
Post by wpaulvogel »
The trick to a Trainwreck is to bias the output tubes hot, at least 75% dissipation, use a 50 foot instrument cable and play it loud. The midrange will swamp the brightness.
Matthews Guitars
It definitely warms up when run pretty hard. I set the volume to about halfway which IS loud and leave it there. And that's the tonal sweet spot. I run it through an attenuator and use the attenuator as the volume control.
Matthews Guitars
Another answer that works well for me....I just use my Mesa horizontal 2x12 cabinet with V30s in it. The darkness of that cabinet has a synergy with the brightness of the amp. It sounds killer....despite them being V30s.
Post by Mark »
Matthews Guitars wrote: ↑Sat Jul 05, 2025 4:32 pm Another answer that works well for me....I just use my Mesa horizontal 2x12 cabinet with V30s in it. The darkness of that cabinet has a synergy with the brightness of the amp. It sounds killer....despite them being V30s.
If you have a look at pictures of the various Express and Liverpool amps, there was an amp possible Maloo which had a largish cap in series with a pot across the plate resistor of the second triode stage. I did experiment with 2200pF and a 1000pF coupling cap and the amp sounded bassier to me. There is a limit to the value of the cap before the amp sounds lifeless.
http://www.amparchives.com/folder/1854/
bcmatt
Post by bcmatt »
I've continued to experiment trying to address this issue because I also like the eq/gain affect of having the bright switch on. Currently in my Liverpool and Express I have either no presence or a preset wired in amount and use that pot position for a cut control. In my Express, I keep upping the cap value for the cut... I think I'm currently at a 0.01uF.
Cut control seemed to work better when I removed NFB completely, but I want the faster transition from clean to mean that NFB provides.
