Rocket Power Transformer
What do you guys think about this power transformer for a Rocket? do you think the voltage is high enough? It's a toroidal 240-0-240 rated for 50 VA.
http://www.antekinc.com/details.php?p=671
These transformers are quite nice, especially with the cases.
http://www.antekinc.com/details.php?p=734
Re: Rocket Power Transformer
I used the older version of that PT in a two tube 12AX7 and EL84 SE amp with ss diode rectifier and had a B+ voltage of about 325V ...jul059 wrote:What do you guys think about this power transformer for a Rocket? do you think the voltage is high enough? It's a toroidal 240-0-240 rated for 50 VA.
I have data from builds using several of the Antek PT's and they seem to have lower voltages in circuit than a standard EI transformer with the same voltage rating ...
I don't know about it powering a Rocket ... maybe a 1/2 Rocket, also there isn't a 5V rectifier tap
well, the 50mA does not cut it even for half a Rocket. If you want to veer off the map, one should at least keep an eye on your tube data sheets.
I realise I described the wrong transformer. Please go see the link!rock_mumbles wrote:I used the older version of that PT in a two tube 12AX7 and EL84 SE amp with ss diode rectifier and had a B+ voltage of about 325V ...jul059 wrote:What do you guys think about this power transformer for a Rocket? do you think the voltage is high enough? It's a toroidal 240-0-240 rated for 50 VA.
In the spec sheet, it says 241 V at 0.4 A secondary. Did you wire the two secondaries in parallel?
From what I gather from this site : http://www.ampbooks.com/home/classic-ci ... power-amp/, this would be in the proper range for an AC30. Is the rocket that much different?
My brother and I and several others have used/tested and shared voltage data for several different Antek PT's (granted most of our testing was done on the AN series transformers and now they have changed a bit and are the shielded AS series) ... from our testing, their data does nor correlate with our in use data, some PT's do perform better than others ...jul059 wrote:I realise I described the wrong transformer. Please go see the link!rock_mumbles wrote:I used the older version of that PT in a two tube 12AX7 and EL84 SE amp with ss diode rectifier and had a B+ voltage of about 325V ...jul059 wrote:What do you guys think about this power transformer for a Rocket? do you think the voltage is high enough? It's a toroidal 240-0-240 rated for 50 VA.
Our testing was done on low power SE and PP amps with an 18 watt being the highest current draw circuit ...
I now see the error in their spec's ... their spec's are what you would get if you only load the HV taps ... in a tube amp both the filament supply and HV are loaded so you will not get 241V @ 400mA from the HV with a heater load on the transformer ...
The Antek 1T300 works well in a ss diode rectified 5E3
I used Duncan's PSUD II to model an amp with the Antek 1T250 ... in that amp it modeled as a 250V 90mA transformer ...
I've used the Antek HV primaries in both a center tap orientation with a full wave rectifier and paralleled with a bridge rectifier both give about the same voltages ... lower than an Edcor, ClassicTone, Hammond transformer with the same spec's.
It would only be a ~$45 experiment to see if the AS-1T250 will work in a Rocket or not ... so build a ss diode rectified Rocket and hook one up and see how it works
They are cheap PT's ... I use them in experimental builds, amps that I don't really value ...
Also the case you have referenced is for one of the 50VA PT's not a 100VA PT so that won't work.
As far as I'm concerned it's not worth spending the ~$20 on the case ... you'd be better off spending another $25 or so on a real Rocket PT.
Thanks rock_mumbles.
I'm thinking it might give some great sag to the amp. What do you think?
sorry, double post.
OK, I just did the math on an AC-30 PT, I'd expect the same for a Rocket ... it's a 200VA transformer ... the Antek is a 100VA transformer.
So it looks like my initial feeling that the Antek would be OK for a 1/2 Rocket was correct ...
Right. Thanks! Looks like I'm out of luck. The next 200VA available transformer from Antek is 300V. A little too high I think.
Antek Toroidal PTs
I have purchased three transformers from them in the past before I knew how to figure the final rectified and filtered voltage under load. Unfortunately, no matter what configuration I chose, the end voltage was well over 500 volts, too much for even the JJ 6L6 and 6V6. I don't quite understand why they would make tube power transformers that aren't useful for guitar amps. Yes I know I can use an EL34 setup with a lowered screen voltage but I leave that to the Hi-Fi guys. I'd use them in my amps if they worked.
Ken Zuercher
Zuercher Amplification
www.zuercheramps.us
Ken Zuercher
www.zuercheramps.us
Re: Antek Toroidal PTs
What was the rated VAC of your transformers that had over 500 VDC once rectified?Hepcat wrote:I have purchased three transformers from them in the past before I knew how to figure the final rectified and filtered voltage under load. Unfortunately, no matter what configuration I chose, the end voltage was well over 500 volts, too much for even the JJ 6L6 and 6V6. I don't quite understand why they would make tube power transformers that aren't useful for guitar amps. Yes I know I can use an EL34 setup with a lowered screen voltage but I leave that to the Hi-Fi guys. I'd use them in my amps if they worked.
Ken Zuercher
www.zuercheramps.us
350 Volts per secondary. 700 total Pk to Pk. So 700 divided by two is 350 (duh) X 1.414 give 494 volts after rectification. Needed 325 and didn't know then (three years ago). The transformers are still on a shelf (just looked at them to get the secondary voltages.
Just returned to the Antek web site. The only 320 volt transformer is a 50 watt unit. They do have a 275 X2 100 watt unit (out of stock naturally) for $34 but it has no 5V winding. I'm OK with the SS rectifier and may do a version of a Rocket,mixed with a Matchless DC30 to see what it sounds like. I don't clone amps anyway, just start with the best designs and tweek them to my taste.
