Before you do anything, check the latest revisions. I had the B3+ and B5+ reversed. Check the updated LO above. I'll have to get Omar to put it into the archive. Sorry for the confusiontitanicslim wrote:... I have them before me as I finally connect everything up on my Liverpool build.
Liverpool Schematic and Layout for critique
Re: Liverpool Schematic and Layout for critique
Tim
- titanicslim
Thanks, Tim
I'll go over it once more whilst I'm laid up with this ear infection. I went into the Files and checked out the lead dress on those filter caps in http://ampgarage.com/forum/viewtopic.php?t=19 under "1990 Trainwreck Express Pics".
I seem to be pathologically disposed to regard people who can do lead dress like Ken F. as mutants. I think my next T'wreck will feature double decker boards for those caps, like I've seen others do. More work but, as Brother Clint said, "A man's got to know his limitations."
The denunciation of the young is a necessary part of the hygiene of older people, and greatly assists in the circulation of the blood. - Logan Pearsall Smith (1865 - 1946)
This LO was just meant to be a place to start. When you're building an amp for yourself, there's no right or wrong if it suits your ears. I plan to stack 20's on 40's as Ken did. I think, after discussing it with Dana and Allyn, the hookup on the filter caps is authentic.titanicslim wrote: I think my next T'wreck will feature double decker boards for those caps, like I've seen others do.
The consensus seems to be that, since Twrecks walk that fine line between tonal bliss and anarchy*, lead dress is very important. Builders like Allyn, Dana, and others have there lead dress pattern down cold. I, on the other hand, will likely be in the chassis with chopsticks like a Chinaman on an order of mu shu pork, figuring mine out But, then, that's the learning process, isn't it
*Conservative as I am, a Trainwreck is likely as close to anarchy as I'll ever get Yeah I'm a rebel
Tim
Liverpool layout revised above: Ground wire for R17,18 added. Thanks, Pete
Tim
- titanicslim
Thanks, guys! I had just gotten to that point in wiring my board in and was about to ask about it when I noticed somebody beat me to it. Pretty close to applying some juice, now. Gradually start hooking up the trannies (No, that doesn't mean I'm finding dates for the neighborhood girls ) and checking as I go. Wish me luck!
Dave
Dave
Tim, the PT's center taps from the HT & heater secondaries are missing.
Larry
Larry
Larry,novosibir wrote:Tim, the PT's center taps from the HT & heater secondaries are missing.
Danke sehr Sie haben recht
Tim
Humbly requesting some amp pics based on this layout. Thanks!
I'm in the middle of building my first Express at the moment. I plan to move on to the Liverpool next and drew this layout in preparation for that AND while waiting on Express parts. I'll be posting pics when I can and probably crying for help The layout was largely based on the Liverpool allynmey built:oggidog wrote:Humbly requesting some...
http://ampgarage.com/forum/viewtopic.php?t=1738
Tim
