Express / Rocket
Schmirleroo
Express / Rocket
Post by Schmirleroo »
Any thoughts on marrying a Express pre-amp section to a Rocket power section?
didit
Re: Express / Rocket
Post by didit »
Schmirleroo wrote: Thu Nov 19, 2020 5:09 am Any thoughts on marrying a Express pre-amp section to a Rocket power section?
Liverpool?
Best .. Ian
Schmirleroo
didit wrote: Thu Nov 19, 2020 9:31 am
Liverpool?
Best .. Ian
Yes... except the power section I'm referring to is tube rectified and cathode biased..
didit
Post by didit »
Schmirleroo wrote: Thu Nov 19, 2020 10:56 am
Liverpool?
But a Liverpool is cathode biased.
Significant differences between Liverpool and Rocket power amp section are in the details of ---
  • split cathode bias,
  • values of various key resistors,
  • and the choke before the screens,
  • the nominal voltages derived upstream from the power supply,
To be strict, Rocket is missing a negative feedback loop too.
Tube rectifiers are in broad strokes really no different than silicon rectifiers despite mythologies spread by certain evacuated mystics.
Best .. Ian
Schmirleroo
didit wrote: Thu Nov 19, 2020 4:48 pm
Liverpool?
Tube rectifiers are in broad strokes really no different than silicon rectifiers despite mythologies spread by certain tube mystics.
Best .. Ian
Indeed it is sir... :)
R
Post by Mark »
There is a bit more to it than that. The Liverpool also uses 1K screen resistors in lieu of 100 ohm. The 1K offers less bass response and does make sense with the Express style preamp.
The 1K choke resistor dials in the sag for the amp as opposed to using a choke.
hitchcaster
Post by hitchcaster »
why not build a liverpool with a SS rec / tube switch... bet you'll keep it on SS tho.
