M Fowler wrote:That part # drawing still looks to be 1/4 to me not 5/16.
I have the same chassis in my shop I will test fit the Cinch to it.
The outsize deminsion is .375" so it will cover any excess. I use the banana jack version of this same test point. So I can test fit it later, still at my day gig.
About 5 miles south of I-94
aka K0GWA, K0 Glas Werks Amplification www.glaswerks.com
I have generally drilled my own bias pin holes on the back apron of the CE chassis as they are more easily accessible.
I have always used the .080" pin type because then I don't have to change the pins on my DMM.
Most of these jacks have plastic bodies, but the best ones I have used were made by Pomona, a quality company, and had gold plated steel bodies. US-made. These use the 1/4" chassis hole.
Also more than adequate are the Cinch metal bodied ones, which have a gold plated solder pin. These use the standard 1/4" hole.
I got both from Mouser, see pic w/P/Ns. Oddly, the Pomona are a little cheaper than the Cinch. Neither are real cheap though.
When I was a boy I was told that anyone could become President. I`m beginning to believe it--Clarence Darrow
