Marcusnorburybrook wrote: ↑Tue Sep 25, 2018 9:40 pmTony,talbany wrote: ↑Tue Sep 25, 2018 6:57 pmMarcusThe 1 u rack version really only makes sense if the rest of your FX are rack mounted this day and age the high end stuff like Eventide H9- Strymon-etc are all pedal format so no need for racks anymore.
Checking out the H9 appears not to have a line level input?..So I am confused? are you talking about using the H9 in the loop or in the front of the amp?..If you run it in the front don't you run into problems with having too wet a mix when you switch to the OD side due to the added gain or are you just hanging on the clean side and use the floor for everything like how Robben runs his rig now.
BTW.I can never get low-level inputs on floor boxes to sound good in my loop because the signal gets too squashed at the front end of the pedal and have to jack the signal up after it.(series loop)
I know in the studio at really low vol levels I could maybe make that work but I can never seem to get it to sound or feel good at loud gig volumes I sometimes play.
Not trying to be a pain.Just wondering how you run it,or if I am missing something!
My H9 is on my main board so it's on an FX loop chain with other time/modulation FX that goes into the Dumbleator.
If it's grab and go I use a Strymon flint, TC nova delay in front of the amp.
Marcus
Very cool and thanks for the reply and the impressive pics of your set up
Here is what I have found running these amps live over 10 years now.
In general it's usually best to keep both the loop and the effects your running in the loop back by the amp to keep all the cables as short as possible, otherwise, you will kill your highs.
Also in order to preserve maximum signal strength and purity, coming out of the amps preamp, the Dumbleator works best when kept at line levels.This also can help with the noise floor coming from recovery amp in the D-Lator.
I am usually more concerned with the headroom in the preamps of my effects than I am with algorithms or clock speeds because I want to pump as much signal into my effects from the Lator as possible and leave as little recovery as possible.(stomp boxes usually have poor headroom) I am just a simple reverb /chorus /short delay set and forget player.
If I run my time based effects into the front end of the amp, my Overdrive channel becomes useless! in a live setting
BTW.Not trying to say you get a bad tone or am telling you how to run your rig for the sound you are chasing in the studio for whatever levels you run or situations your in
Just sharing with you my advice and what has worked best for someone who lives in the rabbit hole and over many years of playing these amps live
Take it or leave it
All the best!
