Starting a D'Lite
Re: Starting a D'Lite
Depending on the brightness of your amp/guitar/speaker combination, you might want some smoothining in the chain somewhere....'bad cable' with high pf, can be one of those.
In my Dlator, (which is run in parallel mode with effect/dry ratio done in the d'lator as opposed to mixing in the effects unit), I've added a 100 pf across the return input, to compensate for not having the direct signal running 4 feet worth of high pf cable. The result; it really takes out the edginess of running a 57' RI strat through a #124 clone through a Thiele EV12L cab. ....guess changing the 40pf on the master volume for 15pf, would do the same smoothening.
How did you set that up?In my Dlator, (which is run in parallel mode with effect/dry ratio done in the d'lator as opposed to mixing in the effects unit)
I love my rail tone amp!
As you can see on the schemo, all I did was adding a 220k serial resistor and 'moving' the return volume from after V1b to before V1b. Hereto adding a small capacitor compensating for the lack of high end loss, from not having the direct signal travelling through feets of cable. You can off course leave that out if you want to preserve high end.JimiB wrote:How did you set that up?In my Dlator, (which is run in parallel mode with effect/dry ratio done in the d'lator as opposed to mixing in the effects unit)
I have left out the bright switches. I never use them and don't think anybody does really.
The cathode resistor combo on V1a can be either 27K/1.8K or 10K/1.5K as per the 'official' schematic.
Getting down to the final (lol) parts order and the one part I can't seem to find is the 100k trimmer in the OD network
Help? anyone got it handy?
Eric
Eric
Something like this? http://www.mouser.com/ProductDetail/Pih ... hB9g%3d%3ddreric wrote:Getting down to the final (lol) parts order and the one part I can't seem to find is the 100k trimmer in the OD network
Eric
from: http://www.mouser.com/catalog/catalogUSD/640/714.pdf
Thank you 2X
Almost ready to build!
Eric
Eric
I am just about ready to start a build based on the layout and schematic below. Before I take the plunge are there any warnings, caveats, suggestions or opinions about the build?
Thanks in advance.
Eric
Thanks in advance.
Eric
Hendrix once said that the combination of the Strat and Marhsall was just way too much treble. I've seen a closeup of his amp that shows the setting, volume 10, treble 0 middle 5 bass 10. Tried it, with a coil cord and guess what, sounded just like Jimi Ok nothing like Jimi.talbany wrote:If you take a look at any footage or for me had the giant ceiling covered picture of Hendrix playing Woodstock (Cool Poster).. Ever notice the cable he used.. That giant coil like on your telephone handset in the 70's...
If you took that cable and stretched it out he could probably run back and forth on the stage 3 times...Those things for capacitance were the worst...I remember reading in one of his interviews that what went with him aside from his guitars were a suitcase with a few Dallas Fuzz Faces a Wah RM Octavia and that big ass cable with the built in treble bleeder... Stevie was the same way.Cesar go to Radio Shack and pick me out the cheapest cord on sale.. .So I doubt 8' of cheap Beldon will keep anyone up nights..
Back in the 60's we all used those coil cords. It was to prevent the cable dance, you know, were you step on your own cable, fall down, rip the jack outta your only guitar and disconnect from the amp all in one step.
Caveats
Used this plan for my build and it produced a fantastic sounding amp! If you follow the schematic, the presence pot is NOT wired as shown in the layout.dreric wrote:I am just about ready to start a build based on the layout and schematic below. Before I take the plunge are there any warnings, caveats, suggestions or opinions about the build?
Thanks in advance.
Eric
Caveats
Thanks in advance.
Eric
On the schematic there's a jumper between the 1st and 2nd lug on the bass pot. On the tweaked layout it's not there. Who knows which is correct? On my tweaked d'lite I put the jumper in. I may try cutting it out.
Here's my amp,
Chip
Thanks for posting and sharing your build. Looks like you added a second trimmer in the PI section (why?????) and the middle toggle seems different than the layout.
Did you put all this together yourself or did you go with a kit? Turrets! love the way they look! I got a chassis and boards set from RJ and am gathering parts as we speak.
Did you use an alpha 2K for the presence?
Eric
Eric
The pot below the board is the bias pot.
Looks like you grabbed the layout that I corrected.
Some of them had the Standby and OT CT wrong, the one you posted is correct.
