HRM Bluesmaster 50 PI trimmer help
Re: HRM Bluesmaster 50 PI trimmer help
Correct. Set that level then remeasure B+ and recalculate (B+ will drop a bit).
Yes, it dropped down to 451VDC
So that would mean 43.2 mA. You could tweak it up to there and call it good.
Thanks for everyone's help.
One last question. Do I need to adjust the bias or PI trimmer every time I replace one of the tubes?
Readjust the PI trimmer only if you change the PI tube, and maybe the power tubes if there is a difference in matching. I would recheck the bias and the PI balance after a few hours of use since the tubes may drift some.
