DUMBLELATOR - who has build one?
Hallo,
does anyone have experiences by building one?
Are there any complete schematics, I only found the one on schematic heaven but there is no power supply...so what about voltages.
Do you have any pictures from DIY D-LATORS?
Hope my english is not too bad
Greetz from Berlin
Greetz from Berlin
Re: DUMBLELATOR - who has build one?
Bob I has helped me out with this. Look at my recent post about sourcing parts. Bob explained how he powered his Dumbleator and I am going to follow his lead.
TJ
TJ
thanx, found the post...tonejunkie wrote:Bob I has helped me out with this. Look at my recent post about sourcing parts. Bob explained how he powered his Dumbleator and I am going to follow his lead.
TJ
Greetz M
- ElectronAvalanche
Heya Mötörböt!
Before spending time building a Dumbleator clone, check out the Flexloop by fellow german builder Ulrich Rodenberg:
http://www.flexamp.com/
Dominik
Dominik
Aloah Dominik,ElectronAvalanche wrote:Heya Mötörböt!
Dominik
japp I've seen this site and the stuff but I want to build one of my one. It is for a friend and I want to be flexable by building it. Just looking for some advice how to realize it and you guy's have done it.
But thank u anyway for your post.
Greetz M
Holy shit! Got enough channels?ElectronAvalanche wrote:Heya Mötörböt!
Dominik
I think at that point the guy should make it programable, that is just toooo much!
- ElectronAvalanche
did you see this:
http://www.flexamp.com/images/custom1_580.jpg
Sort of like an amp where you can change all parts (caps, resistors), circuit on the fly.
I need to visit Ulrich to check that monster out. This can really help you find and tailor your sound.
@Mötörböt:
I will take some pics of my homebrew Dumbleator tomorrow.
Dominik
@Mötörböt:
Dominik
[quote="ElectronAvalanche"]
@Mötörböt:
Thanks, I'll look forward to your pictures.
Greetz M
@Mötörböt:
Greetz M
Hi again,
...are there any inside pix of a original Dumblelator available?
Greetz M
Greetz M
- ElectronAvalanche
Hi Mötööörbööööt,
here are some pics of my homebrew.
The goal was to build one with parts I already had (enclosure) and as cheap as possible. That is why I used the two flatpack transformers.
The heaters are DC and regulated for 6V DC. No hum whatsoever.
Filtering for the B+ is rather large with three filter caps in series. You can probably get away with less filtering, but I had a Fender Brownface tremolo (phase shifting style) in there before, thus the three nodes.
[img:600:279]http://www.dominik-termeer.de/Dumbleator2.jpg[/img]
[img:600:959]http://www.dominik-termeer.de/DumbleatorPS.jpg[/img]
Dominik
Dominik
Holla Dominik,
thööööönk u for the pix.
I'll take some parts from a dead HK cream machine for the PSU.
Do you have some idea to give the dumblelator a parallel loop where I can fade between the wet and the dry signal?
Best Greetz M
Best Greetz M
there's a thread i started, search for tut best fx loop, and parallel fxs, by swt. dogears and other nice guys helped me and there's a useful mix of a dumbleator and the tut series/parallel fxs loop. if you don't find it, i can send you the schem.
Hi swt,swt wrote:there's a thread i started, search for tut best fx loop, and parallel fxs, by swt. dogears and other nice guys helped me and there's a useful mix of a dumbleator and the tut series/parallel fxs loop. if you don't find it, i can send you the schem.
thanks for your info and I found the thread. But it is hard for me to follow the discussion, my english isn't good enough.
There is a file on Blue Guitar called "tut_loop.gif [25k] Tube buffered FX loop from King TUT" but is is removed.
If you have a schem of your final and working version and want to send it to me... M =
Greetz from Berlin M
Hi,
so far I have all the parts and information to start building the thing.
Thanks to ElectronAvalanche, swt, and tonejunkie for support and information.
Greetz M
Greetz M
Hi,
this will be the psu for the Dumblelator, the part for high voltage is not jet done, voltage for heaters works fine.
