Good options for the RG59/Coax cable/wire...
Paul-in-KC
Post by Paul-in-KC »
All,
I got a great tip from forum member "Matt J" on some thin flexible coax (RG188-double shielded). Unfortunately after ordering, I find that they are not going to have it in stock until September. Also, Pasternack (the vendor) seems to be the only one carrying this (at least from my Google searches thus far).
Can someone post a few of their favorite picks for the coax to use in D-style builds?
Seems like thin and flexible would be best.
Thanks!
-Paul
norburybrook
Re: Good options for the RG59/Coax cable/wire...
Post by norburybrook »
MakerDP
Post by MakerDP »
See if you can find what you want here... it looks like you have to buy at least 10 or 25 feet but it's not too expensive.
https://www.digikey.com/products/en/cab ... yword=coax
I'm vewwy happy with this Mogami 2330 shielded coax. Outside diameter is 3mm.
You can order here, $0.30/ft, free shipping, no minimum order:
https://www.markertek.com/product/2330/ ... k-per-foot
Beat that!
Paul-in-KC
xtian wrote: Tue Jul 03, 2018 6:34 pm I'm vewwy happy with this Mogami 2330 shielded coax. Outside diameter is 3mm.
Beat that!
I'll have to order some of that - because it's almost free to have a look. :mrgreen:
Thanks!
BTW - I found some "military grade" (so they say) RG-174 at Antique Electronic Supply for $0.67 per foot. So, ordered ten feet of that. Outside diameter is 0.105"
Paul-in-KC
Beat that!
I ordered 30 feet. Can't beet the price AND free shipping.
amplifiednation
Post by amplifiednation »
Steve at ApexJR has the RG188A/U n stock. RG316 is great too. Teflon is the best
Amplified Nation
www.amplifiednation.com
@ampnation
Paul-in-KC
amplifiednation wrote: Thu Jul 05, 2018 1:42 am Steve at ApexJR has the RG188A/U n stock. RG316 is great too. Teflon is the best
Thanks for that update!
Ordered some of the RG316 for comparison.
BTW - any opinion on the RG174?
Paul-in-KC
So far I have received the RG174 and the Mogami 2330. Both of those seem quite nice.
The Mogami is more flexible/supple. I believe for two reasons. The outside sheath seems to be softer and the shield isn't braided. It's just fine strands of copper twisted around the core. But seems like the shielding property will hold up until the outer sheath is removed. At which point it's easier to prepare for soldering than a shield that is braided. No surprise that the Mogami cable would be nice - as they have a pretty good reputation in the pro audio cable arena (at least that's my impression). At $0.30 per foot and free shipping - I'd say it's a steal. Nice suggestion xtian!
I have a couple of other options coming - so will wait to see the rest and use whatever I like the best. But I think either of the first two would be fine.
-Paul
Paul-in-KC
Received some Beldon RG316 (84316) today from ShowMeCables.
Looks cool. Clear sheath with braided shield. Similar to the RG174 that I got - except the clear sheath seems to be a bit stiffer.
Bombacaototal
Post by Bombacaototal »
I had enough of using the RG59/U as well. Too large and stiff and the core breaks too easily.
Struggling to find PTFE (teflon) Shielded in Europe. Has anyone had better luck?
erwin_ve
Post by erwin_ve »
Bombacaototal wrote: Thu Aug 23, 2018 10:12 am I had enough of using the RG59/U as well. Too large and stiff and the core breaks too easily.
Did you try Conrad?
Bombacaototal
erwin_ve wrote: Thu Aug 23, 2018 10:44 am
Did you try Conrad?
Thanks Erwin, I had not tried them. I could not find on their online stock but I sent them an email.
Also got some RG316 in the meantime.
AtomCap
Post by AtomCap »
https://www.ebay.com/itm/222173816088?_ ... .S1.R1.TR1
Bought 100' of this a while back, have using it with builds and repairs, works great, silver plated, teflon, low pF/FT..
Paul-in-KC
AtomCap wrote: Fri Oct 19, 2018 6:25 am https://www.ebay.com/itm/222173816088?_ ... .S1.R1.TR1
That looks pretty good - and pretty good price too.
Thanks for adding that to the pile!
