High Plate Classic? Should We build it.
I've been slowly building parts for my next build to scratch my obsessive compulsive addiction of these amps and help get me out of this Covid slump
The only ODS I have not tackled yet is the High Plate Classic. I know most of you out there are Skyliner freaks and that's cool! I get it,Sky is a great stack no question although I really like my low plate classic with single coils and played at low volume levels and at times miss that High plate sound especially on the OD Side.I also know the mids will be a bit scooped (although there are ways around that). Anyway, I thought I would ask around first.(anyone play one?)
Here are a few H.P.C's in action..Would you build one?... Be honest?
Mick Taylor Leopard skin
Gregor's 094
Gregor's 094
Re: High Plate Classic? Should We build it.
Hi Tony. I also love the low plate classics. With single coils its pure heaven! The Classic tone stack has always been my favorite tone stack especially with a 100k - 120k slope.
But your right about the Overdrive sounding different in a good way with the High Plates. I would definitely also build a High Plate so you can have the best of both worlds!
With your skills I am sure it will sound amazing!
I am building one now for the same reason, just so I can enjoy a different flavor of Overdrive.
Cheers
Guy
Cheers
Guy
Double yes. To be honest, I think it is my favorite circuit. I like the classic stack with the 150k slope and higher plate loads. It is more scooped but very Fender friendly. I had the one Gregor is playing under my bench for a couple weeks.
CW
My Favorite !11years ago I built my first Dumble Clone,a silverface with the funky OD Entrance,that developed into a low plate Classic into a high Plate Skyliner into a high Plate Classic with a .05 mid cap into a 250k pot,150k Slope,mid boost and a 500k Bass Pot, my favorite Speaker is a JBL K120,Lots of character
So it appear the High Plate Classic was also a preferred circuit for a Strat by HAD. According to Max here #123 was also a H.P.C and was built for a Strat Customer.Charlie Wilson wrote: ↑Mon Mar 08, 2021 8:14 amDouble yes. To be honest, I think it is my favorite circuit. I like the classic stack with the 150k slope and higher plate loads. It is more scooped but very Fender friendly. I had the one Gregor is playing under my bench for a couple weeks.
CW
https://ampgarage.com/forum/viewtopic.p ... 3&start=30AFAIR it's correct, that #0123 has been built for a strat player (AFAIR: 1956 maple neck). But AFAIR #0123 isn't what's called a "low plate classic" here, but what's called a "high plate classic" here.
There is also some conjecture that 123 (like it's sister) 124 that it too has a 350k OD entrance trimmer? You wouldn't happen to know if #094 had that setup along with a 250k OD Level?
So far The leopardskin amp Mick is playing is a better representation! and the OD sings like a high plate..The only thing I worry about is the clean channel sounding too clean w/ lots of headroom and flatter top end, especially with NFB on V1B..I am contemplating adding a 716 mid cap to brighten it up a bit although it will still be missing the extended top the Low plates have..Any Thoughts? Ideas? suggestions?
Did you get that from #94? TonyAFAIR the original owner of #0123 requested two amps with clean channels staying completely "clean" at large volumes, too. And AFAIR that's exactly what the clean channel of #0123 does. Nice (IMO) OD, too, with AFAIR "flutelike" (in my perception) OD harmonics.
In the interest in trying to give back some support to this forum, I drew a SCH version of #94 that is easy to read and can quickly be edited.
It does NOT have all the information that Tony's PDF file has but can perhaps be useful as a "quick" glance of the schematic circuit. This is not intended to replace the #94 PDF file which is more complete.
CHECK for ERRORS! Compare carefully to the #94 PDF file.
Note the SCH file has two pages to it.
IF someone finds an error in the SCH version feel free to post the corrected SCH schematic or simply post a reply and I will edit it.
with respect, 10thtx
I have a schem of #094 with a 1M OD Trimmer, 152k to ground,100k pots
- erwin_ve
If you can make it sound like this, yes:
The build up and 2.40 with PAB and Drive is very nice sounding...
The 1M trimmer is visible in the pic. Considering #124 with a 500k measuring 345k , Im curious what this trimpot really is.
Wow that is a large trimmer , 1 M.
I imagine having more resistance before entering the overdrive stage will make the overdrive sound a little less tight and maybe add some compression and increase lows?
Guy
Guy
Erwin
No way I am putting a 1M there! That aint happenin..The lows would be all over the place, especially with a 250k Drive or Level..It's my understanding (but it's been awhile) that scraping the trace (removing carbon) increases the resistance..The only other explanation was he used a different pot casing and installed a scraped or altered trace element?..You got me there.If I could verify the value I could get a lower value trimmer and remove some carbon. 250k..Thanks for the Y.T clip of #094 I had not seen that one in a long time!..We got us a Screamer
1 meg. I believe that is why he used the .02 cap in the HF taper. Notice also, #94 does not have the 500pf bypass on the 220k. Clean is kind of flat and compressed sounding. OD is quite gainy and crunchy sounding. We really need to find some 221k Roderstein MK3s. Tony, I am sure you are aware of this but Gil knows a bit about the High Plate Classic.
CW
1M Trimmer with 150k to ground equals 100k trimmer with 40k to ground.Add the 220k ,there is a 7:1 ratio ( 280k:40k / 1070k:150k) so 12,5% Signal feeding OD 1
So it looks as though whomever owned #094 at one time thought the amp was too bright?..IMO the H.P.C is one of the Darkest of ODS Models, . I was just over on another thread saying I have never seen an amp that didn't have the 500 Pf well here it isCharlie Wilson wrote: ↑Tue Mar 09, 2021 6:49 am1 meg. I believe that is why he used the .02 cap in the HF taper. Notice also, #94 does not have the 500pf bypass on the 220k. Clean is kind of flat and compressed sounding. OD is quite gainy and crunchy sounding. We really need to find some 221k Roderstein MK3s. Tony, I am sure you are aware of this but Gil knows a bit about the High Plate Classic.
CW
So it looks as though I will be using the Combo as my template instead of #094, looks to be more my style and I also have a bit more info on this amp and know several who have actually played it and spoke highly of it..As for the MK'3's will start the hunt If none show I may be forced to use the NTE's until a set pops up..My other High plate has them in it and seems to do OK for now,I know the MK'3's will make a difference.I already have a set of 150's
Will Be in Touch
