Revisit #0183 with 5-piece chassis
ijedouglas
Post by ijedouglas »
After building my last amp with a 5-piece chassis and really liking the results I decided to give my #0183 the same treatment and rebuild it into a new 5-piece chassis. So far I'm loving the results. The amp was pretty good prior to the rebuild (period correct parts (for the most part) and period correct transformers) but straight away I noticed a much clearer top-end and more note definition and separation, This could well be due to slightly different lead-dress but I'm more inclined to believe the thick chassis has something to do with it. I had the same feeling from the last high-plate skyline that I did. Here are a couple of pics:
Ian
erwin_ve
Re: Revisit #0183 with 5-piece chassis
Post by erwin_ve »
Nice Ian!
A rebuildi of this kind requires a lot of motivation I guess...
I'm curious on the thickness of the chassis, what do you think happens to the final result tech wise?
Erwin
Beautiful!
How did you compare the tone, before vs after?
ijedouglas
erwin_ve wrote: Tue Nov 14, 2023 9:35 pm Nice Ian!
Erwin
Thank you.
I'm not 100% certain but I think it has to do with the grounds. I know that chassis composition (steel vs aluminum) makes a big difference to the tone and I have to believe a thicker harder chassis would change the tone too. I paid particular attention to repeatedly testing the ground points and making sure that all had 0R between them so that may also contribute.
Ian
ijedouglas
xtian wrote: Tue Nov 14, 2023 9:58 pm Beautiful!
Thank you.
Incredibly scientifically :lol: ....just joking, I had a pretty good idea of what the amp sounded like in the room before the change so it may well be confirmation bias, but I certainly hear more clarity and note separation.
Ian
GAStan
Post by GAStan »
01+ Looks GREAT Ian!!!
You sure do set a good example for us noobs to follow.
Metalwork is topnotch, hope you didn't let any blood out like I usually do...
The front and rear panels look really good, did you do them yourself?
Glenn
I solder better than I play.
ijedouglas
GAStan wrote: Tue Nov 14, 2023 10:35 pm 01+ Looks GREAT Ian!!!
Thanks Glenn. Yup, front and back panels are drilled, sprayed with Krylon Black gloss, apply vinyl decals and coat with clear gloss.
Ian
dbharris
Post by dbharris »
Fantastic work Ian! As always from you, this is a reference build.
-Dan
bepone
Post by bepone »
very nice, i bought U profiles and cut top side Aluminium to size, hope soon i will start mine too
ijedouglas
dbharris wrote: Tue Nov 14, 2023 11:07 pm Fantastic work Ian! As always from you, this is a reference build.
-Dan
Thanks Dan
Ian
ijedouglas
bepone wrote: Tue Nov 14, 2023 11:24 pm very nice, i bought U profiles and cut top side Aluminium to size, hope soon i will start mine too
I'm interested too hear your opinion once completed?
Ian
ViperDoc
Post by ViperDoc »
WOW. Beautiful amp, man.
How did you construct the wood-metal side walls, and how are they connected to the rest of the chassis and with respect to chassis ground? How does the mahogany affect the tone? :lol:
Just plug it in, man.
ijedouglas
ViperDoc wrote: Wed Nov 15, 2023 3:41 am WOW. Beautiful amp, man.
Thank you.
Red oak panels.
Each wood panel has 7 screws. 3 secure the side to the base and then there are 4 screws, 2 from the top and 2 from the bottom through the front and back c-channel. Extremely rigid and strong.
Ian
Stephen1966
Post by Stephen1966 »
Beautiful work, as ever!
Stephen
www.primatone.eu
ijedouglas
Stephen1966 wrote: Wed Nov 15, 2023 12:58 pm Beautiful work, as ever!
Thanks Stephen
Ian
