New Project
7 others liked this
New Project
This project has been on the back burner for a while, but now making progress in the last couple of days stuffing the boards. The main board was made by Tony D from my drawing, FET board is my KiCad design, fabricated by PCBWay. Second photo is test-as-you-go in the extreme; HV power supply no-load check.
- ElectronAvalanche
Re: New Project
Nice!
What is this? Intrigued.
Best,
Electron
Best,
Electron
Re: New Project
Very interesting Martin.
Are you working on a racked version of the ODS preamp?
Fred.
Fred.
Re: New Project
Now that's a thing of beauty right there!martin manning wrote: ↑Sun Mar 24, 2024 4:46 pm This project has been on the back burner for a while, but now making progress in the last couple of days stuffing the boards. The main board was made by Tony D from my drawing, FET board is my KiCad design, fabricated by PCBWay. Second photo is test-as-you-go in the extreme; HV power supply no-load check.
If only we could get a decent 2 channel power amp into a rack space like Mesa 20 20... From my research it's just too costly, especially here in the UK.
Re: New Project
Sorry for making you guess, but that's close ;^) There's more iron there than a preamp would need, but the power supply on this board could easily be modified to do that. Maybe I should draw one up!fred.violleau wrote: ↑Sun Mar 24, 2024 5:56 pmAre you working on a racked version of the ODS preamp?
Next step: chassis drilling.
Re: New Project
Thanks, Rog. Seems like a tube pre and a SS power amp would work. IDK how much power you are thinking, but a 100W Class D power amp would fit, not sure if there would be noise issues, but you can buy boards pretty cheap; $100 or so.rogb wrote: ↑Sun Mar 24, 2024 6:22 pmNow that's a thing of beauty right there!martin manning wrote: ↑Sun Mar 24, 2024 4:46 pm This project has been on the back burner for a while, but now making progress in the last couple of days stuffing the boards. The main board was made by Tony D from my drawing, FET board is my KiCad design, fabricated by PCBWay. Second photo is test-as-you-go in the extreme; HV power supply no-load check.
Re: New Project
Single ended amp?
Re: New Project
Yes! With built-in resistive load and pseudo-balanced line out.
Re: New Project
Cool. Will be watching with interest as I cycle through preamps in my ever-evolving SE platform.
Re: New Project
Very cool project Martin! I'm looking forward to watching this build.
-Dan
-Dan
Re: New Project
I've been down the Class D road and bought a Palmer Macht 402 power amp. Unbelievable amount of power and very well made for £289.martin manning wrote: ↑Sun Mar 24, 2024 7:33 pmThanks, Rog. Seems like a tube pre and a SS power amp would work. IDK how much power you are thinking, but a 100W Class D power amp would fit, not sure if there would be noise issues, but you can buy boards pretty cheap; $100 or so.rogb wrote: ↑Sun Mar 24, 2024 6:22 pmNow that's a thing of beauty right there!martin manning wrote: ↑Sun Mar 24, 2024 4:46 pm This project has been on the back burner for a while, but now making progress in the last couple of days stuffing the boards. The main board was made by Tony D from my drawing, FET board is my KiCad design, fabricated by PCBWay. Second photo is test-as-you-go in the extreme; HV power supply no-load check.
But it was lacking that Dumble PI interaction that flavours the sound we love.
I got a Mesa 20/20 power amp that sounds really good.
It seemed there was no way to recreate 2 x tube power amps in a 1U space without spending a crazy amount of time and money.
Better to find a Mesa and tweak that. I added bias adjustment and fat switching, it's very good and there are PIs to hit with preamp signal!
But please keep feeding us more about your project. Looking at the transformer, you could be running a pair of 6V6 or 6L6?
Re: New Project
The 20/20 must be pretty crowded inside, maybe a bit hard to work on?
My project is a single ended amp, so no PI. I don't know if I'll miss it since the Dumble power amp is pretty much a clean Hi-Fi type. It's a bit of an experiment, so I'll just have to see how it turns out. The preamp is a copy of my 100W low-plate, so it will be interesting to see how much different it sounds with the low-watt power section.
Re: New Project
Very much looking forward to seeing it!martin manning wrote: ↑Mon Mar 25, 2024 10:23 am The 20/20 must be pretty crowded inside, maybe a bit hard to work on?
I've got a little SE EL34 I built into a rescued combo cab, great sounding and full of character. I guess you'll be paralleling a pair of tubes?
The Mesa is not too bad to work on actually. Well laid out for its size.
Re: New Project
Hello --
Could you start by assembling the SE power stage and feeding it with your existing low-plate loop to verify?
Look forward to learning what you do discover. Somewhat skeptical foregoing the PI. A dummy load on the input triode and then pulling output drive from second maybe? This is something I recall seeing when someone was designing to couple into a class D power brick.martin manning wrote: ↑Mon Mar 25, 2024 10:23 am My project is a single ended amp, so no PI. I don't know if I'll miss it since the Dumble power amp is pretty much a clean Hi-Fi type. It's a bit of an experiment, so I'll just have to see how it turns out. The preamp is a copy of my 100W low-plate, so it will be interesting to see how much different it sounds with the low-watt power section.
Re: New Project
Years ago Mat in Finland posted a SE ODS with no "phase inverter." By all accounts it sounded great https://ampgarage.com/forum/viewtopic.p ... rm&start=0
There have been a number of others since then, search the forum on "mini hrm".
In my own (limited) experience, I found running my "Hybrid Rev A" preamp into a SE power amp sounds just fine, at least at the bedroom volumes I use.
