So after searching the forum and other sources for hours I was first at the impression that closest to 007 is something like an SSS 002 with Dumbleland PI\power section (12AU7/12BH7 AC coupled driver) until I found with 67Plexi's "SSS 007 Build" now here is where everything gets messy:
Back in 2014 67Plexi "confirmed" the PI to be 12au7/12bh7 ac coupled driver. Talk was about reverb section etc
Then here comes 18 June 2016 the build. It is stated that it is using 3x 12ax7 and 2 12bh7a's with 6550. So I assume it was still basically an SSS preamp + ODR 2 tube Reverb and Dumbleland power section(with 2 12bh7a's for PI). (Actually it can be directly the SVT power section so DC coupled)
But now comes the real interesting stuff 28 Spetember 2016. Plexi67 confirmed he saw gut shots of 007 and had a friend that worked on a later version and said that:
Stevies SSS's are with 8 preamp tubes!
Here is the description V-1 EF86 , V2 EF86 for master(????), V-3 7025 side of 12dw7 for high step filter, v-4 12dw7 7025 side for Low Step Filter, PI is 12ax7 with 12ax7 cathode follower.(and ODR 2 tube reverb ofc)
This raises questions but I think this explains a Silver Aligator with step filters but step filters are somehow using two tubes for recovery? Can someone explain what is the deal with it? How you implement the filters that way...Also we were pretty sure that PI was Dumbleland.....
[And comes 21 February 2017 which claims SSS 150 watts are V-1 EF86, V2 EF86, V-3 EL85, V-4 12DW7 and a single 12au7 PI (Now this is weird, I do believe all the 150 watt Dumble's had pi+driver/follower) now the preamp section's tube count is reduced from 6 to 3!.... how is this gonna work...?]
Anyways I think most accurate info was the 28 Spetember 2016 which specifically mentioned SRV's amps. But how would we come up with a schematic for this any thoughts guys? Am I understanding something wrong?
Here is the best I could come up with the preamp (but step filter recovery is one tube since I have no idea how to make it use 2 tubes)
SSS #007
Re: SSS #007
Now the back of a Blackface of SRV. On this amp 2nd tube next to 6550’s are taller. So it is 12bh7 pi>12au7 driver instead?
