Hi Guys,
I have a loop on the board using a flatpak trannie. It is fed with a 12VAC supply. As I was sketching it out, I wondered about not creating a ground loop between the main amp chassis and this. There is plenty of room to take the AC supply out of its case, bolt it in the chassis and then feed regular AC to the unit. Barring that, should there be some sort of chassis connection?
Thanks, Skip
PS, Funk, where did you get those 1U PT's? sh
D'loop flatpaks
- Funkalicousgroove
Re: D'loop flatpaks
I have them custom made, I can get you one if you want. Did you see the pics I posted of the Real Dumbleator?
