Where does sustain come from?
- skyboltone
Re: Where does sustain come from?
The real explanation requires a familiarity with certain vocabulary not real common to those without proper training. I think the following should prove useful to those who would endeavor to obtain vocabularial improvalence.
http://www.youtube.com/watch?v=RXJKdh1KZ0w
Compression is a known contributor of sustain. Also, Feedback which excites certain frequencies to resonate, like a tuning fork. Reducing phase cancellations can encourage sustain. The trainwreck third stage is a compression stage which creates sustain. also, the hi gain nature of the preamp probably encourages resonate feedback , which can encourage sustain. Compression in the power tubes also creates sustain.
Hmmmm. Quite crombulent not to mention florenthomic. I like the boturamatic and pouriscopic way he speaks.
Word!iknowjohnny wrote:Hmmmm. Quite crombulent not to mention florenthomic. I like the boturamatic and pouriscopic way he speaks.
- skyboltone
My favorite is still:
"The original machine had a base plate of pre-famulated amulite, surmounted by a malleable logarithmic casing, in such a way that the two spurthing bearings were in a direct line with the panametric fam".
The body language is priceless.
"spurthing bearings" I love that. I have no idea what they are but I think I need to incorporate them into an amp. It could open a whole new opportunity for qualified techs to "recalibrate the spurthing bearings."
I think that is right on.billyz wrote:Compression is a known contributor of sustain. Also, Feedback which excites certain frequencies to resonate, like a tuning fork. Reducing phase cancellations can encourage sustain. The trainwreck third stage is a compression stage which creates sustain. also, the hi gain nature of the preamp probably encourages resonate feedback , which can encourage sustain. Compression in the power tubes also creates sustain.
It makes sense because when you use a compressor pedal the sustain increases dramatically.
Bob-I,What? you didn't like my answer
Actually, I just about blew beer out the nose!! While not the technical answer I was looking for, I suspect there is much to be said for heaven and the Magic Smoke.
I promise I will stop messing around with the the settings of my amp. I sure don't want to mess with the space/time conti
That's as far as I got. I'm all choked up.ted01 wrote:Hey CaseyJones,
With all due respect (and I mean that, I've learned a ton from you), on this, you're just wrong.
HOW did I miss this one?skyboltone wrote:My favorite is still:
Bob I is of course right on track with this one. High gain is compression, beyond a certain point the amp "ignores" more signal than it can amplify. In its own good time the amplitude of the plucked string comes down to a level below the maximum amplification the preamp is capable of, that's when it starts to fade away. It fades away if you don't do any further "magic tricks", for instance a nice wide vibrato will excite the string enough to keep the note going. Lots of gain, a nice wide vibrato and acoustic feedback... grab this guitar and hold this note for me, my wrist is gettin' tired!
Sorry I can't explain it better than that. I'll try to do better next time.
Sustain come from Ezekiel 25:17
Major Twang
Major Twang
I'm still hanging on to the pixie dust theory.
- skyboltone
"The lineup consisted simply of six hydrocoptic marzel vanes, so fitted to the ambifacient lunar waneshaft, that side fumbling was effectively prevented. The winding was of the normal lotus "O" deltoid type placed in panendermic semi-boloid slots of the stator, every seventh conductor being connected by a non-reversible tremupipe to the differential girdle spring on the up end of the grammeters. Moreover when ever fluorescent scoremotion is required, it may also be employed in conjunction with a drawn reciprocation dingle arm to reduce sinusoidal depleneration."CaseyJones wrote:HOW did I miss this one?
Notice how he points his thumbs up when he mentions the "up end" of the grammeters? Wow. Now that's acting. Tom Cruise eat your heart out. I used to play that tape for operations people who often thought they had a pretty good handle on what the technicians were up to. After about a minute viewing the tape you'd start to see the deer in the headlights look.
It takes one to know one... Dan, you're surely as unstable as I am. I can tell because you took the time to transcribe that schtick. Unless... you scripted it to begin with.skyboltone wrote:"The lineup consisted simply of six hydrocoptic marzel vanes, so fitted to the ambifacient lunar waneshaft, that side fumbling was effectively prevented. The winding was of the normal lotus "O" deltoid type placed in panendermic semi-boloid slots of the stator, every seventh conductor being connected by a non-reversible tremupipe to the differential girdle spring on the up end of the grammeters. Moreover when ever fluorescent scoremotion is required, it may also be employed in conjunction with a drawn reciprocation dingle arm to reduce sinusoidal depleneration.".CaseyJones wrote:HOW did I miss this one?
By the design brief it sounds to me like it should work.
Just because Mr. Cruise is a raving lunatic doesn't mean he can't act. Remember, it takes one to know one! Hell, they don't call it HollyWeird fer nuthin'! Just look at what that town has done to that poor boy.skyboltone wrote:Notice how he points his thumbs up when he mentions the "up end" of the grammeters? Wow. Now that's acting. Tom Cruise eat your heart out. I used to play that tape for operations people who often thought they had a pretty good handle on what the technicians were up to. After about a minute viewing the tape you'd start to see the deer in the headlights look.
Take poor little Britney Spears for example. She's not as strong in her convictions as Mr. Cruise. She was just a nice little girl from Louisiana. The whole show biz thing is all about givin' the people what they want. They want drama then they want to go to church on Sunday and pretend it isn't like that.
