Altec faceplate ebay find to Class D Amp
norburybrook
Re: Altec faceplate ebay find to Class D Amp
Post by norburybrook »
Mark,
how are you rectifying the AC voltage for the B+ on your layout?
Marcus
p.s. here are some high quality power supply modules
https://www.hypexshop.com/shop/shop.jsp?groupID=117
JazzGuitarGimp
Post by JazzGuitarGimp »
I was wondering about the (huge) power supply too. Is it a linear supply, or a switcher? It sure looks big enought to be linear...
Lou Rossi Designs
and Schematic Capture
Here are the amp module and power supply info.
Sure 600w Class D 320-311-parts-express-manual.pdf
Sure 48v 12A 600w power supply 295929.pdf
norburybrook
Guy's if you check out those Hypex power supplies you'll see they're small. They're also ,along with their class D amp modules incredibly high quality, probably too high for a guitar amp, but my mastering engineer recently upgraded his amps that power the high end PMC's he has and used two mono Hypex amp kits he built. He's very picky about everything but the Hypex amps he says are amazing. Not cheap at over $1000 per channel but small efficient and most of all a great sound.
Marcus
andresound
Post by andresound »
I built 2x Hypex mono blocks with NC400 modules and associated power supplies about 5 years ago. They are in my main Hi-Fi system. Haven’t missed a beat and sound truly “High End”. Great product designed by a digital genius!!
Coyotesgator
Post by Coyotesgator »
Thanks for the cool idea!
I think I’ll give it a go.
Cheers!
What Happened?
Who let the magic smoke out?
Coyotesgator
M Fowler wrote: Sat Nov 04, 2017 10:25 pm In my case the Altec came with a 25k volume pot and rotary on/off switch with matching knobs MXR style so decided to use both of those items.
Still using the 25k pot?
Have you experienced loading and loss of high frequency below 7/8 travel?
What Happened?
Still using the 25k pot and no loss at all.
I run my home made tube preamp into the Class D power amp.
