JMI AC30/6 NO SOUND
Re: JMI AC30/6 NO SOUND
No volts between 9 and 4/5
All valves and lamp turns on but not HT :/
If the tubes are lighting up then you DO have voltage between preamp tube pins 4 and 5 which are jumped together and then pin 9, but that AC voltage, not D.C. Voltage like your testing on the other pins on the tubes!
I don't want to sound mean, or cut you down, if you don't know this simple basic detail then a can't see how when you introduce yourself here that you posted / stated that you build amps I am sorry to say.
Everyone can make a mistake, I build some amps but I had a mistake now XD
Sorry you are right, it's voltage between 9 and 4/5 (6.40volts)
OK, you'll have to see what's going on inside the power amp chassis.
There may be a problem around the rectifier or the choke.
What are the VDC on the can cap terminals?
You forgot to connect the rectifier tube pin 8 to the filter caps! That explains no high voltage.
EDIT... Looks like the HT fuse is mistakenly connected to rectifier pin 4. Should connect to pin 8.
This is my ones
https://drive.google.com/file/d/11OB8En ... p=drivesdk
https://drive.google.com/file/d/11NkxC5 ... p=drivesdk
Really! That would mean the PT yellow wires are the high voltage wires and the PT red wires are the 5 volt wires. That's a very unusual color code for a PT.
Measure the DCV on pin 8 of the rectifier. Then measure the DCV on each choke lead.
But first, check the HT fuse.
Fuse it's okey, pin 8 of rectifier 0.640 vdc
Measure resistance from pin 8 to chassis with power off. Should be very high.
Can you see the rectifier filament glowing?
Measure the ACV from pin 4 to chassis. Looking for approx. 300VAC.
Measure the ACV from pin 6 to chassis. Looking for approx. 300VAC.
Measure ACV ***BETWEEN*** pin 2 and 8. (This means one probe on pin 2 and the other probe on pin 8.) Looking for approx. 5VAC.
