Hi !
I built a 5F6-A with only one input
But i put the input and build board from left to right ( like a Trainwreck) instead of right to left...according to layout.
Do I have to invert the Wire on pot ?
Exmp, Pin 1 to pot gonna go on pin 3, middle stay the same ???
I also switch the middle and Bass pot position
Simple but confuze me a little !
Thanks for Help !!
Dave
Help on Pot Wiring please
Re: Help on Pot Wiring please
pot wiring stays the same.
That's my side! Indeed wiring the pots requires something of a mental training, when you're doing things the opposite way as most do, and layouts read.
(unless you want your pots to act counter-clockwise ;-)
It always helps me to make a drawing like this.
Think about what the pot is doing as you turn the knob from 0 to 10 on the front panel. Use a DMM and get to understand which way the wiper is moving and which pins are which. If you're lucky, the schematic will show the pot pin numbers and a little arrow next to the letters cw, which show you which way the wiper moves on the schematic when turned clockwise.
I highly recommend using some other hosting besides photobucket, the limit views and now we can't see your image.
If you can't upload it here, try google photos or imgur.com.
how about this?
Hey , Thanks !
Her's how i do it and it work like a charm.
