Princeton reverb coming together (need some help)
- JoshBernstein
Hi everyone,
I've put in a bunch of work on my Princeton reverb build. All that's left is the bias board. I'm waiting on a new 100uf cap for it, as the first one they sent me was dead shorted!
Any feedback would be great.
I've got an amperex bugle boy for the input tube, Sylvania 12au7 for the reverb driver, RCA short gray plates for v3 and v4. New production JJ's for output tubes and rectifier. I plan on using that 10" Jupiter speaker and an old ruby reverb tank I had. Classictone OT and heyboer for the reverb driver and PT.
There's just so many wires in these damn things, I think I'll hold off on the fender builds for a while.
Not really
Re: Princeton reverb coming together
Oh, you're going to love this amp, Joshyboy.
Looks good Josh.
Love the red theme. Doin' your own thing and not worry about the traditional thing. Cool. What brand of resistors are those?
Bryan
Bryan
- JoshBernstein
Thanks everyone!
The resistors are PRP, I got them here:
http://www.partsconnexion.com/resis_prp_main.html
Not really
The 100VDC caps in this amp are huge. I take it that you wanted to build an amp with high quality parts. It should be very quiet.
- JoshBernstein
Well I fired it up today! The clean tone is absolutely amazing, the best I've heard.
I've got a few issues to work out, maybe you all can help. First the reverb sounds kinda odd. Like it floats on top of the note and is very washy. I'm guessing it's the reverb tank, as it's not exactly the one the circuit is designed for -- it's a ruby tank, numbered rrvs2eb2c1b. I also used a 12au7 for the reverb driver. Also a bit of hum is added as the reverb is turned up. Would this be lead dress or tank placement?
Also, at lower volumes the amp is quite quiet. But as I turn it up, I get this weird hiss/hum noise I've never heard before in another amp. Is there anything there anything that should be suspect?
Thanks!
Thanks!
Not really
Re: Princeton reverb coming together (need some help)
First thing to check is what all your DC voltages are (B+, and at each filter cap power supply node, each plate, cathode, grid)
- JoshBernstein
Will do. I'll post some voltages tonight.
Not really
Yes, tank placement can influence hum. And you've got to get the right tank, so the impedances and grounding scheme match the circuit.
- JoshBernstein
Definitely will do. Would I be okay leaving the 12au7 as the reverb driver? Also could I use the Accutronics 9AB2C1B or should I stick with the 4AB3C1B? It would be sweet to have the 3rd spring in there.
Not really
12AU7 will have increased current over 12AT7, but if nothing has smoked by now, it's probably ok. Neither of the tanks you mention carry the ground through from input to output. The send cable shield must be grounded in your amp, usually by tying it to the return cable shield ground. AB2 is medium decay, AB3 is long decay, both are 8-ohm input, 22k5 output.
You need to study the reverb pan data the 2 in 9AB2C1B is medium decay and the 3 in 9AB3C1B is long decay.
If switching to 4 type pan 2 spring long tank there is a difference in transducer and Reverb Driver ohms.
- JoshBernstein
Looking at the specs, the 9ab2c1b has an input impedance of 10 ohms. The reverb driver has an 8 ohm tap. Is this too significant of a difference for it to sound good? I just thought it'd be nice to have the 3rd spring for a more complex sounding reverb
Not really
- JoshBernstein
Based on this I'll give the 3 spring tank a shot. And I'll ground the two shields together. Thank you!martin manning wrote: ↑Sun Apr 30, 2017 10:29 pm 12AU7 will have increased current over 12AT7, but if nothing has smoked by now, it's probably ok. Neither of the tanks you mention carry the ground through from input to output. The send cable shield must be grounded in your amp, usually by tying it to the return cable shield ground. AB2 is medium decay, AB3 is long decay, both are 8-ohm input, 22k5 output.
Not really
