The build with the 40/20/20/20 has no other filters (it is a Fender-ish build). The 40 is the main filter, and the 20's are PI and preamp. This cap can was selected because of space considerations (and the values are correct). Not sure I will do this again though - to restrictive.M Fowler wrote:Actually I think if I had a 40-20-20-20 can cap I would ground that by itself. The main filter can cap 30/30 or 40/40 or 50/50 not sure what is being used I would ground with HT CT.
Then if your going to use TW buss solder to the pots I would run the remaining ground near the input jack rather over by the cap stack as TW does it.
train wreck grounding
