Anderton '64 reissue JTM145 - any info?
Marshall Amp Discussion
electrochimp
Re: Anderton '64 reissue JTM145 - any info?
Post by electrochimp »
cool stuff. I see they use that on some el84 equipped amps too.
thanks
Ksandr
Post by Ksandr »
may be can somebody check the printed circuit board? tubes are on the back side printed circuit board
Littlewyan
Post by Littlewyan »
What program are you using for that file?
Ksandr
Post by Ksandr »
sprint layout 6.0
jazbo8
Post by jazbo8 »
Ksandr wrote:sprint layout 6.0
Could you please just post the PDF?
Ksandr
Post by Ksandr »
Connection pcb with potentiometers for some reason does not show
jazbo8
Post by jazbo8 »
Great, thank you! Need to put on my glasses and have a closer look...
inkomodo.dragon
JTM1 Final Schematic
Post by inkomodo.dragon »
Hi guys, I've just read all the thread but can´t seem to find the last version of the schematic (03/09/14).
The last one I can find is the one from 28/08/14
Can someone please upload it?
Thank you very much to all of you who worked on this
Matec
Post by Matec »
Hello guys.
The last major revision is that of 28/08/2014. But it was posted on 03/09/2014.
The circuit is always being revised, but these small changes do not invalidate the previous circuits, less than a major change is announced.
Cheers 8)
Matec
jazzkramer
Post by jazzkramer »
Much time is gone but no one post the JTM145 Tone stack board and Input Board... :(
Littlewyan
Just to give you guys a heads up, I bought myself a Mullard ECC82 for my JTM1 (Which if you remember rightly is really a JMP1). Anyway I swapped out the JJ ECC82 with the Mullard and the difference was amazing. The amp has so much more clarity with the Mullard and the bass is a lot better. With the JJ I tried using JTM45 values for the 1st stage coupler and cathode bypass cap but it couldn't handle the bass. I reckon the Mullard will take it just fine, but thats an experiment for another day.
Anyway the valve cost me £16 + £4 delivery on ebay from Langrex (NOS Valve Dealer). http://www.ebay.co.uk/itm/271320551803? ... EBIDX%3AIT
Allynmey
Site Admin
Post by Allynmey »
sturgeo
Post by sturgeo »
Does anyone have a schematic of what we believe the JTM145 is, Matec's HTM1 with paralleled volume controls?
dorrisant
Post by dorrisant »
sturgeo wrote:Does anyone have a schematic of what we believe the JTM145 is, Matec's HTM1 with paralleled volume controls?
I'm very interested in this too.
I don't know if anyone has tried the schematic Littlewyan posted on the very bottom of page 4. That seems to be the closest I have seen to the two-volume control concept anyway. Wish we could have seen the control board in those pics build posted on page 16. Wish we could have got to know him... :roll:
I built the AX84 Swamp Thing many years ago a SE design rather then 1w but the preamp is similar and the dual gain pots work very well a dark/bright mix of V1a&b.
