#189 50W Bluesmaster(Ripper?) Photos
Re: #189 50W Bluesmaster(Ripper?) Photos
I think the most interesting part is the od.Could that be the megaplex?
But it's hard-wired... There is no PAB as we know it.ToneMerc wrote:Variabe pad for the PAB.
Martin with pab off both mid and bass pots are grounded through the relay.
With pab on the trimer is parallel with the 22m resistor for a milder bluesmaster boost.This has been discussed in the past as a more strat friendly pab.
That makes sense. What about the strange R/J switch wiring? Has that been seen previously too?
I think it has been discussed in a thread about L.Carlton's amp.
The conclusion was that the pab relay also lifts the jazz cap from ground for a more useful sound when in jazz mode with pab on.
- UltraHookedOnPhonix
Charlie, thanks for the super sweet shots!
Some stuff I notice:
-EL34, 50W (what kind of OT me thinks?)
-Has mains voltage selector switch.
-PS dropping string: 3K-->15K-->10K
-HRM trimmers: treble about 30% up, mids and bass set to about 60% up.
-Main filter cap bank: 50uF (two 100uF in series)
-5nF Jazz/Rock cap goes to PAB relay instead of ground.
-All 715P in the PI.
-100K feedback resistor to 8R tap.
-Presence pot is 50K//47K for approx. 25K total.
-No OD trimmer.
-150K OD2 grid resistor.
-FX loop jacks are isolated from chassis (like #177 and #183).
-Must've been one of the last amps with the wooden-sided chassis?
About the PAB switching...correct me if I'm wrong but I'm pretty sure this is what we're seeing:
-No OD trimmer.
I think many similarities with this amp.Thanks for your contribution Charlie once again.
Seconded, and thanks to UHOP for the schematic, too.
This thread needs to be moved to the D files section.
Very informative thread. I may have to tweak the 50w bluesmaster. I have a one button foot switch that engages PAB + OD always together. This looks like a very tweakable and workable alternative to that.
Thanks again, Charlie!
- Reeltarded
At the rish of being dismembered by someone here on the Dumble thing..rp wrote:It's unlikely a molten meteor hit a Dumble, but if you catch that blue-goo throbbing and growing better run.
lmao
Mike it is a green tolex head. A few more photos.ToneMerc wrote:CW, was this by chance a black suede 1-12 combo with a EV?
Mike
CW
Charlie - appreciate you sharing the pictures!
I think my gutted Fender HRD is going to become a Bluesmaster!
Regards,
-jack
Regards,
-jack
John 15:12-13
10-4, thanks as always.Charlie Wilson wrote:Mike it is a green tolex head. A few more photos.ToneMerc wrote:CW, was this by chance a black suede 1-12 combo with a EV?
Mike
CW
Mike
I have been informed that this amp may be a Ripper. Bluesmaster PI, Skyliner tonestack, and JCM800 OD. Larry Carlton circuit?
CW
CW
