D-lator Tutorial step by step as I do it.
BobW
Re: D-lator Tutorial step by step as I do it.
Post by BobW »
Very informative! Thanks for sharing your knowledge and expertise.
Funkalicousgroove
Post by Funkalicousgroove »
I hope it helps!
it's a pretty easy project, just a little time consuming.
les_guitar
Post by les_guitar »
Anaconda1126 wrote:VERY cool!!!
Thanks for posting that Funk.
Just out of curiosity, how much do you charge? I might be interested in purchasing one in a couple months.
FWIW, I bought one and I am very pleased with the result. It sounds so nice to be able to run effects on my Bludo-drive.
Highly recommended!
Thanks Brandon...
Funkalicousgroove
Thank YOU les!! I'm glad you're enjoying it!! the #1 Purpose of these builds is to act as a "Smile Generator!!!" :D
jelle
Post by jelle »
Brandon,
Thanks for the tutorial! Appreciate it!
Jelle
drew
Post by drew »
Thanks for the tutorial.
Are the orange, red, and blue parts of the shielded cables all heatshrink?
Funkalicousgroove
yes, I put heatshrink on both the ground drain as well as the signal lead to prevent melt back during soldering, as well as re-inforcing the wire.
odourboy
Post by odourboy »
Brandon,
I've just finished mine today and the result raises a question...
What sort of attentuation should I expect from the cathode follower side? When I crank the send level to full, I appear to be getting significant attentuation compared to the output from the preamp (For some reason, I was expecting unity gain). I can easily compenstate with gain on the return side, but I'm concerned that I'm getting correct operation.
Thanks! Brian
Funkalicousgroove
There should be an attenuation, otherwise I think it would act as more of a distortion stage than a buffer. Have you double checked that you have it wired correctly? You should also try a few different tubes, I have a VTV triode characterizer that I use to evaluate my 12AX7's, I usually choose a balanced tube, or one that is slightly hotter on the CF side.
odourboy
Post by odourboy »
Problem solved. Extremely stupid operator error - one of my scope probes was on X10. Dooh! :oops:
Funkalicousgroove
I've been known to screw up WAY worse than that!! LOL!!
erwin_ve
Post by erwin_ve »
Thnx for sharing really helpfull!!
Funkalicousgroove
enjoy
angelodp
Gepco DS401
Post by angelodp »
Funk you refer to the " drain " for the grounding, I assume that is the center bare twisted wire used for ground/drain. Then only one of the conductors is used for the signal and the shield is discarded? Or do I twist the foil into a wire and use that as the ground ??
ange
Funkalicousgroove
The bare wire is the drain
