You Got it!
The 2nd gen layout in the files section is virtually the same amp! if you are looking for a layout w/parts (Phiers/Dales/Flexfoam/Sprague TVA's & PS series/Fender Iron) the usual suspects used in that generation. It's all there!
BTW.This is a KILLER AMP!! and recommend it for those who like the so-called "Fender clean sound"
with an aggressive focused OD! (cuts through the mix)..Great for slide players.I highly recommend building one (Use BLACK PLATE 6L's)
Tony, putting the FET on a relay and having the gain on the front socket adds a whole extra dimension to the amp, I've been really knocked out by that.
M
The fet is something I have wanted to add to my 100w version . The clips I've heard with the Fet in this Gen does sound wonderful.My problem is I like both input sounds and want to switch back and forth and am too lazy to modify mine to do the internal switching/New footswitch etc. so I just use an RC Booster on the floor..I do have an extra FET and relay board so maybe I should stop being lazy and do it..Thanks for the inspiration!
Just so you know, Hanks Guitar Shop -> Music Ground -> Your favorite crooks on Denmark street, the f#cking Harrisons
Known for faking pretty much anything music related that's half worth the effort, Dumbles included
Here's one posted by an ex employee some years back:
