Whats up with the pink resistors? Switches replaced too.
First Fischer amp Ive seen with Black shielded wire off the inputs.
![Image](https://i.imgur.com/RjlVcq5.png)
![Image](https://i.imgur.com/SyuXJwJ.png)
https://reverb.com/item/13880759-trainw ... rpool-1992
Smoke rises from the mountain of Doom. The hour grows late and Gandalf the Grey rides to Isengard seeking my counsel. For that is why you have come, is it not… my old friend?there are questions, questions that need answering. I must see the head of my order. He is both wise, and powerful. He’ll know what to do.
The standby switch wiring was pretty common on Expresses and also the lazy heater twists.erwin_ve wrote: ↑Sat Aug 04, 2018 2:43 pm What is different?
The wiring for the standby switch. In original liverpool pics the first node of filtering is powered and then goes to the standby switch.
In the Harrison ad: Right after the diode rectifiers the B+ is going to the standby switch.
No damping with tape foam, which I think is critical in this circuit.
Heater wiring is off, in Liverpool pics it's consistent in relation how many turns used.
The blue wire coming from the plate resistor going to the first triode is running next to the heater wirenever seen that with liverpool pics.
No MOV on the power switch?
