Dumblelator PCB
erwin_ve
Dumblelator PCB
Post by erwin_ve »
Hi,
I've been designing some pcb boards for both ODS and Dumblelator.
This is the file I used for reference: Image
And the attachment is the PCB design.
Could you guys check the dumblelator pcb for errors etc.? It's a 2 layer board: dark traces are bottom side and light traces are top side. Bottom side is in x-ray vision.
dbeasley
Re: Dumblelator PCB
Post by dbeasley »
Looking good man!
Sent from my moto g(6) using Tapatalk
didit
Re: Dumblelator PCB
Post by didit »
Seems we are seeing multiple PCB recently, which is cool. Not picking on this particular one. Wonder about wisdom of tube sockets directly attached however. Fixed more than a few dead duds in commercial designs. Better board material and heavy copper helps. Anyone have evidence to recommend this versus the obvious alternative of flying wires to a socket?
Best .. Ian
erwin_ve
Re: Dumblelator PCB
Post by erwin_ve »
didit wrote: Mon Mar 18, 2019 3:37 pm Seems we are seeing multiple PCB recently, which is cool. Not picking on this particular one. Wonder about wisdom of tube sockets directly attached however. Fixed more than a few dead duds in commercial designs. Better board material and heavy copper helps. Anyone have evidence to recommend this versus the obvious alternative of flying wires to a socket?
Best .. Ian
Hi Ian,
real dumblelators also have the sockets on the pcb. I 've build several and never encountered problems.
fred.violleau
Re: Dumblelator PCB
Post by fred.violleau »
1 question : on some D'lator V8 bypass caps is 5uf. Yours and others is 25uf. What sonic difference would it make?
Thanks,
Fred.
Fred.
didit
Re: Dumblelator PCB
Post by didit »
erwin_ve wrote: Mon Mar 18, 2019 4:03 pm
Best .. Ian
Hi Ian,
Yep, understood. A few Watts heater and at most a few more working Watts off the plate unlikely to be an issue.
For fairness most, though not all, issues past encountered were power tubes -- EL84s in particular -- in upside down orientation.
Ian
norburybrook
Re: Dumblelator PCB
Post by norburybrook »
fred.violleau wrote: Mon Mar 18, 2019 4:35 pm 1 question : on some D'lator V8 bypass caps is 5uf. Yours and others is 25uf. What sonic difference would it make?
Thanks,
Fred.
Fred.
at a guess, how much low end is let through. The 5 uF will filter out more low end.
M
didit
Re: Dumblelator PCB
Post by didit »
erwin_ve wrote: Fri Mar 15, 2019 9:38 pm Could you guys check the dumblelator pcb for errors etc.?
Checked. No outright errors I caught. Might move recovery B+ pad up and away from "Out" output. Out of caution. And your labels might be clearer: "B+1", "B+2" vs "B+" twice; and "recovery in" rather than "grid".
Best .. Ian
erwin_ve
Re: Dumblelator PCB
Post by erwin_ve »
Thanks,
Fred.
Fred.
The cathode bypass cap in my example is 47uF!
As Marcus said in his reply above; it will set the amount of low end.
The difference between 5uF and 47uF is a the roll off point. At 5uF it starts to roll off at 120-130Hz, At 47uF it starts to roll off at 90-100Hz.
For the low E string you got 1dB more with the 47uF cap. It's a tone shaper in the pre-amps for most designs(check twin reverb and ODS differences on the cathode bypass cap.). In case of the dumblelator: all shaping has been done in the pre-amp sections of the ods; So basically you can make it hifi if you want( in the ideal world.)
Rob Robinette, Merlin Blencowe(valve wizard) and Randal Aiken have some useful website information on this topic.
Make sure you search for triode gain stage and load lines first and then cathode bypass cap.
When understanding this, you got a basic understanding how and why different values are chosen for the triode gain stage.
erwin_ve
Re: Dumblelator PCB
Post by erwin_ve »
didit wrote: Mon Mar 18, 2019 6:10 pm
Best .. Ian
Thank you for checking Ian!
The labels are doable except for "recovery in"; that is taking up too much space, done this above and below.
The B+ pad vs Out; good catch, I have to rethink this; the brackets that hold the pcb in vertical mount are also close to the B+ pad.
Erwin
fred.violleau
Re: Dumblelator PCB
@Marcus, @Erwin, thanks for the replies! I read alot about hipass and lowpass filters and sometimes I need time for all the information to sink in ;)
Fred.
Fred.
norburybrook
Re: Dumblelator PCB
fred.violleau wrote: Tue Mar 19, 2019 10:58 am @Marcus, @Erwin, thanks for the replies! I read alot about hipass and lowpass filters and sometimes I need time for all the information to sink in ;)
Fred.
Fred.
:D it's one of the things Dumble did to take 'fender' amps into 'Dumble' territory. If you look Fender used 25uf cathode bypass caps on a lot of amps whereas Dumble ODS amps tend to be 4.7 / 5uF, this tightens up the bottom end a lot and stop the flubiness you can get when driving a fender hard. Combine that with extra power filtering and you get an amp that holds together a lot better at volume.
M
didit
Re: Dumblelator PCB
Post by didit »
erwin_ve wrote: Tue Mar 19, 2019 10:20 am The B+ pad vs Out; good catch, I have to rethink this; the brackets that hold the pcb in vertical mount are also close to the B+ pad.
Suggest simply move that B+ "wire" solder pad up to the point where the trace bends to come down to the bottom edge.
erwin_ve
Re: Dumblelator PCB
Post by erwin_ve »
And The PS Filter board:
erwin_ve
Re: Dumblelator PCB
Post by erwin_ve »
didit wrote: Tue Mar 19, 2019 1:19 pm
Maybe; I'll do a paper model on that one with the mounting brackets, as soon as the mounting brackets arrive.
