sluckey wrote: ↑Fri Jan 17, 2020 3:42 pm
Sounds like you're just about done. I do suggest trying a linear taper 250K pot.
Thanks Steve, the 250KB (linear pot) is what I had to start with, but unfortunately I could only hear the effect with the pot turned to 3 o'clock, or in other words almost at maximum.
I think I will add a 24K in parallel with my 100KB pot (making it 20K) and then wire as a reverse variable resistor. Then I just need to define if my resistor in series (ie minimum position) will be 4.7K or 9.1K
Just tested, sounds great! No need for the second “minimum” resistor, just 100kb with 24k across is perfect. Has no effect on the amps tone (or very little), I was going back and forth between the trem in the circuit and off the circuit with the effect OFF via footswitch to compare.
I call this done! Many thanks Sluckey, it was a fun experiment and experience
sluckey wrote: ↑Fri Jan 17, 2020 7:45 pm
Give us a good sound demo. There may be others interested in putting this trem circuit in their amp.
Sure, will do some tomorrow. For future reference the output of the VTL is very prone to crosstalk so a good layout is important. Also the circuit worked with the added 9K but not with the added 18k. So I think a 25Kb pot would be fine too but probably a 50K would not work.
The INT pot is dependant on the particular injection point. That's why a bit of tweaking is necessary. BTW, are you still connecting the INT pot to the MV pot? Did you ever try connecting to the VOL pot? If so, what were the results?
sluckey wrote: ↑Fri Jan 17, 2020 10:18 pm
I went back to the MV, haven’t tried the Volume pot again today to be honest but from the experiments yesterday I preferred the sound of it at MV then at the Volume.
I think that sounds great! And such a simple circuit too. Would you post your final schematic in case someone wants to add this tremolo to their ODS style amp? Maybe even start a brand new thread titled "Adding tremolo to an ODS" or something similar? If you do this be sure to include that nice sound clip.
