JMI AC30/6 NO SOUND
Travis8
Re: JMI AC30/6 NO SOUND
Post by Travis8 »
Yes, rectifier os glowing.
Pin 8 to chasis 0 ohms
Pin 4 to chassis 282 ACV
Pin 6 to chassis 283 ACV
Pin 2 to Pin 8 5.14 ACV
That's the problem. Something is shorted to chassis. Suspect the first or second filter cap. Or wire shorting.
Remove the HT fuse. Is pin 8 to chassis still 0Ω?
Travis8
Post by Travis8 »
sluckey wrote: Mon Aug 09, 2021 5:50 pm
Yes, still 0 ohms!
Travis8
Post by Travis8 »
I move the fuse holder and now it's 3.47 M Ohm pin8 to chasis!
But when I try It again was 0 ohms again and now it's 19.16 M ohms!
Travis8
Post by Travis8 »
Sometimes I can check M ohms and other times 0
But 90% of times its 0
I have a few quick questions for you.
1. Did you build this amp? When?
2. Has it ever worked? If so, when did it stop working? What was the last thing you did to the amp before it quit working?
3. Do you know the difference between 0 and OL on a DMM?
Travis8
Post by Travis8 »
sluckey wrote: Mon Aug 09, 2021 7:57 pm I have a few quick questions for you.
I didnt build It, I buy It and It was working but one day stop making any sound
OL means infinite
Travis8
Post by Travis8 »
Travis8
Post by Travis8 »
You are right, i use another multímeter and It reads OL pin8 to chasis. Thanks
Travis8
Post by Travis8 »
So the rectifier isn't the problem, maybe it's the choke?
Masco
Post by Masco »
SG = Steve Grovesner the builder for JMI(new).
But of a confusing thread, I’m sure you’ll sort it out :wink: :
Travis8
Post by Travis8 »
Masco wrote: Mon Aug 09, 2021 11:13 pm SG = Steve Grovesner the builder for JMI(new).
Yes. Thanks you all for the help, I'm trying to learn more and solve this
Travis8
Post by Travis8 »
Could I check violet circle to chassis and yellow to chassis to know If this cap and choke are working correctly?
Sorry If I make to many questions, I´m trying to improve my knowledge
Thanks again guys
On your 3rd output tube socket from the left it looks to me from your last photo that pin 3 is shorting to pin 2 .
Travis8 wrote: Tue Aug 10, 2021 9:21 am Could I check violet circle to chassis and yellow to chassis to know If this cap and choke are working correctly?...
Yes :)
pdf64 wrote: Mon Aug 09, 2021 11:59 am ...There may be a problem around the rectifier or the choke.
What are the VDC on the can cap terminals?
