SSS #002 REDRAW DRAFT
Re: SSS #002 REDRAW DRAFT
GAStan wrote: Mon Apr 22, 2024 5:59 pmDid I get it correct?
Would you have bet money that you did? ;^)
GAStan
Post by GAStan »
martin manning wrote: Mon Apr 22, 2024 6:12 pm
Would I have won? :wink:
Glenn
I solder better than I play.
GAStan wrote: Mon Apr 22, 2024 6:35 pmWould I have won? :wink:
You have a point there :^) To me, one component being in series with another means they have the same current.
GAStan
Post by GAStan »
You are correct. It took me reading it several times to catch on-if I did. The "Did I get it correct?" was actually meant for Ryan :wink:
Glenn
rccolgan
Post by rccolgan »
martin manning wrote: Mon Apr 22, 2024 5:48 pm Hi Ryan, it's this. As drawn vs. the red. Your layout shows the red.
oh!! That is much clearer.. Thanks, Martin! I apologize if I missed any communication about this discrepancy before. Looks like I'll need to try it in my amp :shock: and possibly update the layout :D
Ryan
https://www.thetonegeek.com/
No problem, and it basically reduces the output 1 dB if the feedback goes direct to the grid. Other than that, I don't know.
rccolgan
Post by rccolgan »
martin manning wrote: Mon Apr 22, 2024 8:29 pm No problem, and it basically reduces the output 1 dB if the feedback goes direct to the grid. Other than that, I don't know.
Thanks, Martin! Always a cordial interaction with you that I continue to appreciate!
I updated the layout with this correction. Fun fact: I looked through my pictures and I had this arranged correctly at first and somewhere along the line I changed it to the incorrect way. Oh well. I'm glad it's proper again!
Ryan
ViperDoc
Post by ViperDoc »
Just noticing this traffic. Is my "redraw" draft correct, then, with respect to the Reverb input NFB? It looks like it is to me. Best.
Just plug it in, man.
Yes, yours matches the hand-drawn schematic.
