"70ies circuit Bludodrive"
Max
Re: "70ies circuit Bludodrive"
Post by Max »
dogears wrote:Looks like the stack, the trigger, the grid resistors, and PI are 70s. Can't say which, but definately 70s. Teh power supply is probably not the tonal determinant here. So, it is a modern hybrid of the 70s with all essential 70s values there.
Hi Scott,
thanks a lot for chiming in but I still do not understand what you and others refer to as "specific 70ies"?
Please let me explain why:
AFAIR the preamp of a 1st generation "pre-classic" Dumble ODS as an example is much more different from the preamp of a '79 transition generation "classic" amp than, say, the preamp of an Ojai from a usual skyline amp.
So why you are all that sure that this doesn't matter regarding 70ies amps? In the discussion with Mr Dumble you've poined out that the "Ojai tweaks" have a big influence on the tone and its capability to reproduce the "Rugged Road tone".
Another example why I am very unsure what you are talking about: I have never met a "trigger" in a 1st, 2nd, or 3rd generation amp. But you name it as typical for a 70ies circuit.
Because of all this I think it would really help a lot to get out of this confusion, if someone would just post the series number of such a "typical 70ies 100W amp" or a picture or a link to a picture.
Are you talking about something like the Farris amp or about something like Lindley's amp or about something like Lowell George's amp or something like Rick Vito's amp or what kind of amp are you all talking about?
Why not simply posting one picture or one series number or one link to a picture that shows such a kind of amp you all here call "100W 70ies"?
Thanks again for your patience with me.
Max
dogears
Post by dogears »
Soory for using the word trigger to describe the fixed pre-od network. That is what I referred to. Best to email Brandon with any specific questions.
I was mainly saying that the preamp values, grids, od net, PI, etc were all from 70s era stuff. Maybe directly derived from a specific amp, just not sure....
Hi Scott,
Max
FUCHSAUDIO
Post by FUCHSAUDIO »
Interesting, no AC balance and no OD trimmers.....?
Bob Simpson
Post by Bob Simpson »
I realize I'm a heretic, but could threads like this one be flagged with a "Straining gnats and swallowing camels" icon? ( although I'm not sure exactly what that would look like... )
Or perhaps a "Don't waste your time reading this one, it's only boring shit" icon...
again, no input on the icon's design, but it would save a lot of time...
TIA
Bob Simpson
I think it's called, splitting hairs.
Sure this amp has the more modern footwitch/ relay setup but I think what everyone is addressing is the circuit itself, on the main board.
If you look at the layout Tony was so gracious to make, the layout and values on the main board are probably what everyone refers to as a "70's" amp.
Yep the forum software is knackered up again, won't allow me to attach the layout.
Look in the files section for the #40 layout.
talbany
Post by talbany »
Bob
Just trying to address some questions from a fellow Garage member who has contributed a great deal here and IMHO deserves a response..Boring as it may seem to you..
With the ut-most respect!!
hitchcaster
Post by hitchcaster »
kimocks 50w 70's dumble has no AC balance, but has a 25K OD entrance pot. FWIW
glasman
Post by glasman »
FUCHSAUDIO wrote:Interesting, no AC balance and no OD trimmers.....?
The input circuit is the same as what DUMBLE used in the ODRS amps. That funky trim the front end, trim the back end. No new ideas here.
About 5 miles south of I-94
www.glaswerks.com
glasman
Post by glasman »
Actually I think there is a schematic of this "type(or similar)" of amp in the files section.
www.glaswerks.com
Max
Post by Max »
talbany wrote:2...The Classic Stack (In what ever form)
The first amps with a "classic" tone stack have been built in '79. And IMO, please contradict, the pre-classic stack of a 3rd generation ODS is more similar to a skyline stack than to a '79 classic stack of a transition generation ODS. And the 1st and 2nd generation pre-classic stacks are IMO at least as similar to a skyline stack as they are similar to a ’79 "classic" stack. And the kind of parts used in a 1st generation ODS, its layout and everything is completely different from a 2nd or 3rd generation ODS.
3... 12AT7 PI
The 1st generation ODS and the ‘79 transition generation ODS did not specify a 12 AT7 inverter. And AFAIR (will check again) the 3rd generation ODS didn’t specify a 12AT7 too.
4... The Look
The only thing a bit similar concerning the look is the silver chassis. Size, fonts, controls, layout of front and back plate are different. The difference in look between a 1st generation amp and a transition generation amp as an example is at least as large as between some skyline 6L6 non HRM amps and some skyline EL34 HRM amps.
It uses the 3 resistor OD setup
AFAIR this is different in 1st generation amps. ’79 transition generation amps don’t have this at all they have the 80 trigger setup. A ’79 transition amp is nearly identical to #124 before the skyline update of #124 and very different from a 1st, 2nd or 3rd generation ODS.
and the classic stack..(There may have been others)
No, the first ODS amps originally built with a "classic" stack have been ’79 silver transition generation amps. Before this all ODS amps did have a tonestack that has more similarities IMO with a skyline stack than with a transition generation or 4th generation classic stack. If you want to call the pre-classic stack a "classic", why then not call the skyline stacks "classic" too? The skyline stack IMO is more similar to a 3rd generation stack than the "classic" stack to a pre-classic stack.
#13 was an ODSR but still both OD entrance and classic stack and AT PI were born from the 70's..
No, #13 has a different OD entrance than 1st generation. And #13 is a 2nd generation ODR, and of course specifies a 12AT7 PI as all other 2nd generation ODS/R. Other 70ies ODS/R amps (at least 1st generation and transition generation) don’t specify a 12AT7 PI. And #13 doesn’t have a "classic" tone stack. IMO the tone stack of #13 is at least as similar to to a Skyline tone stack as to a classic stack. The first classic tone stack ODS was built in ’79 in the first transition generation amps.
Since the classic stack took on various forms and pot values you couldn't just say classic stack..I know these were used in the later 80's amps as well but came from the 70's designs..apply car name..
No, all transition generation and 4th generation ODS amps have exactly the same "classic" tone stack. Only difference: some with 100K slope, some with 150K slope.
But indeed there are differences between the tone stacks of the "pre-classic" 2nd and 3rd generation ODS and the 2nd and 3rd generation ODR. These differences have been discussed in this thread, at least regarding ODS amps: http://ampgarage.com/forum/viewtopic.php?t=12113
Max
talbany
Post by talbany »
What we mean by the 12AT PI is related to the lower value 47K 51K plate resistors which are more in line with the spec sheet of a 12 AT than an AX.. This does'nt mean you cant use an AX..We refer it as the AT PI..Right or wrong..An AG interpretation..
Yep!! I agree..1st generation and 79 transition OD entrances network were different than the 3 resistor setup like #13 in 77
Thanks for correcting me!!
I never specified the generation of #13 just that it was built in 77..
Addressed the PI issue above..
Then they are not exactly the same
Max Thanks for the info!!
Take Care!!
Runaway J
Post by Runaway J »
To me this amp sounds pretty much like the grey snakeskin specimen Brandon built last year, which is based on #013.
See this thread (page 3):
http://ampgarage.com/forum/viewtopic.ph ... c&start=30
I'd really like to see Mr. Miyagi here again.
Edit - forgot this two:
http://www.thegearpage.net/board/showth ... p?t=597864
http://ampgarage.com/forum/viewtopic.ph ... ce&start=0
... searching for the legendary fourth chord ...
Max
Post by Max »
Structo wrote:If you look at the layout Tony was so gracious to make, the layout and values on the main board are probably what everyone refers to as a "70's" amp. Look in the files section for the #40 layout.
Tom,
what Tony posted is AFAIK no "layout of #040". And this is perhaps the misunderstanding from which all this confusion now arises. #040 is a real 50W 2nd generation Dumble Overdrive Special. Gut pics of #040 you find on Rob Livesey's site.
Tony now used the term "layout of #040" only in a metaphoric sense AFAIK to express: "Here you find my personal cocktail mixture of different circuit specs from different 70ies amps, #40 being one example". But AFAIK there is no single real Dumble amp in existence with this kind of schematic and layout that Tony has posted using the term "layout of #040". But Tony can perhaps tell you himself how he came up with this layout.
BTW:
If some or even most here think that it is a most boring topic to discuss the technical specs of some real Dumble amps that have been built in the seventies, this is absolutely fine with me of course. But I nevertheless think that there is no special "flag" needed for my posts, as Bob Simpson suggested. On the left side of my posts there is already a "flag" that says: "Max" or "Beware, this is one more of these boring nitpicking Max posts!" So where’s the problem? Why don’t you just ignore my posts?
And if some or even most here think that it is a good idea and a promising approach to build replicas of Dumble amps by mixing a cocktail of the pot values of amp A with the tone caps of amp B, the OD entrance of amp C, the power supply of amp D, the PI of amp E, the EQ switches of amp F, the ratio circuit of amp G, the presence circuit of amp H, the coax cables of amp I, the power amp of amp J, the V1/V2 plate resistors of amp K, the slope resistor of amp L etc, this is completely fine with me, too, of course.
But on the other hand I will for sure continue to post here what is my opinion about this kind of "cocktail" approach. And IMO this is complete nonsense.
Why? Because every single Dumble amp has been built by Alexander Dumble as a kind of individual "tone generator system":
"So each amplifier or speaker enclosure can very much be considered a prototype device suitable as a model for mass manufacturing, copying procedures." (A. Dumble)
And because of this, if you want a tone close to #183, I would recommend using the complete #183 system. And if you want a tone close to the amp of Lowell George I would recommend using the complete #13 system. And if you want a tone close to #075, I would recommend using the complete #075 system. And if you want a tone like the 3rd generation ODS of Karl Ratzer ( http://ampgarage.com/forum/viewtopic.ph ... 121#135121 ) I would recommend using the complete 3rd generation system. And if you want a tone like the 2nd generation ODS on the clips I have posted here http://ampgarage.com/forum/viewtopic.ph ... 368#129368 , I would recommend using the complete 2nd generation system. And IMO this would only be possible if you know all these systems. But as some or even most here seem to prefer this "cocktail" approach, I understand of course that you perceive my posts here as boring and nitpicking.
But, Tom, on the other hand you should perhaps understand that as long as I am not completely convinced that all 8000+ members here are not interested in my posts, you will have just to live with them further on. So the best way to avoid that your first cup of coffee is sometimes disturbed by one of my posts will perhaps be to just ignore them in the future.
One more nitpicking remark in regard to the "The power supply does not matter that much" topic:
I do not know much about the details of tube amp technology. But as far as I know this is an AC based technology. And because of this the power supply is of course a part of the "signal path" (a weird metaphor anyway IMO for an AC circuit).
And the different versions of power supplies have a large influence upon the dynamics. And the dynamics have a large influence on how the human hearing system perceives the "timbre" or "tone" of an instrument. The human hearing system perceives a different kind of transient response as an example as a different tonal colour or "timbre" and not only as different velocities of changes in volume.
If this topic should perhaps seem to be interesting for some here, than I can recommend reading one of these books:
http://books.google.com/books?id=qgsst2 ... &q&f=false
http://books.google.com/books?id=eGcfn9 ... &q&f=false
Cheers and happy mixing. Have fun!
Max
erwin_ve
Post by erwin_ve »
Max you better ask Brandon.
He has been in several dumble amps.
Personally; I don't care if it's a mix of different builds; his builds sound awesome to me. So that should be the bottomline here. Make a awesome sounding amp.
I learned a lot about toneshaping using different values for resistors and caps from different builds. It helps to get the picture where HAD is doing the toneshaping.
But there is so much guessing right now, because you never have seen such a thing. Well maybe there is, but you just haven't seen it before...
Max
Post by Max »
erwin_ve wrote:But there is so much guessing right now, because you never have seen such a thing.
Hi erwin_ve,
This is true. I had my own nose only in perhaps 25 Dumble amps and Dumblelators etc. The other perhaps 15 I know indeed only from gut pics. And of course this is probably still less than 10% of all the Dumble amps, Dumblelators etc. Indeed no comfortable database for generalisations. In this I agree.
Max
