Ignore the title of the spread sheet. The form works as long as you have a resistor on the cathode to ground, in this case 1ohm.
Yes the amp is fixed bias.
Here are the numbers you were looking for:
Cathode Current: 56mA per tube
Voltage drop across the common 1K screen resistor 17v (474 in 457 out)
Screen Current: 17mA
Plate Current: 39mA (Cathode Current minus the Screen Current)
Plate Voltage: 470v
Each tube is idling at 18.32W (52.37% Plate dissipation on a 35W tube)
