Aluminum vs Steel chassis
- FUCHSAUDIO
Re: Aluminum vs Steel chassis
Yes, magnetic lines of flux will not travel through Aluminum the same way they do through steel. Aluminum is also a "free" heatsink...for regulators and such. For whatever reason, the same amps in aluminum vs steel chassis seem to sound better (whatever that means) in aluminum fwiw imho.
If you are relying on a steel chassis to carry large return currents and there is flux being leaked into that same area then yes you will be inducing hum from the power transformer. If you carefully control your high current return paths (so that resistivity in these lines is very low and voltage isn't induced) then the flux won't have anywhere to couple to. Or better stated, any flux that is coupled will induce such small currents that the effective noise voltage will be zilch.
Cliff Schecht - Circuit P.I.
I used to use a place called Dirty Dawg amps for my chassis, but now use Seaside exclusively. I've installed my Dual Rec xfrms in both, and the top of the chassis bounces around like a trampoline when hung tubes down.
What thickness are you using?
M Fowler wrote:Various suppliers ebay,bal704 wrote:Who are you getting your chassis from?
M Fowler wrote:I haven't had any stress problems with aluminum chassis using tubes down layout even with 100w transformers.
www.turretboards.com
www.rjguitars.net
http://amplifiednation.com/
http://www.seasidechassisdesign.com/
yeah, you can build from both, and have a good sounding amp - but I like the electrical properties of magnetic fields better for alum than steel. plus easier to machine.Is Aluminum not better in regards to not passing magnetic flux from the PT?
fuchs has it right on with what Ive seen/heard and tested - same amp steel vs alum, alum sounds better - more sweet to my ears.
never had the $$ to try one of those gold chassies - based on my theories that would sound even better - I think its a lot like wire, dielectric resistance, whatever the mojo is called
-> gold better than silver better than copper better than alum better than steel. in theory.
- FUCHSAUDIO
I always liked the idea of stainless, but the costs are really prohibitive. The material costs more, but there is a charge for the tools wearing out much faster, so most people won't use it.
From seaside I get this 12 gauge aluminum type 5052 for custom builds requiring extra strength otherwise his regular grade would be too thin for heavy transformers. Other builders are using stronger material then Seaside.bal704 wrote:I used to use a place called Dirty Dawg amps for my chassis, but now use Seaside exclusively. I've installed my Dual Rec xfrms in both, and the top of the chassis bounces around like a trampoline when hung tubes down.
M Fowler wrote:bal704 wrote:Who are you getting your chassis from?
www.rjguitars.net
- FUCHSAUDIO
There's always the "Mesa solution"
I wonder IF there is a patent on that??? "Voltage transforming support device"FUCHSAUDIO wrote:There's always the "Mesa solution"
Mesa Tone Bolt.John_P_WI wrote:I wonder IF there is a patent on that??? "Voltage transforming support device"FUCHSAUDIO wrote:There's always the "Mesa solution"
PATENT PENDING.
The Mesa Sagulator and you can determine your load requirements using this handy calculator.
http://www.woodbin.com/calcs/sagulator.htm
(deleted)
Damn you guys are a clever and funny bunch!
(deleted)
