#008 Dumble interview with Ben Harper
talbany
Re: #008 Dumble interview with Ben Harper
Post by talbany »
If you use some kind of shielding inside the top of the cabinet you need to clean off the top edges of the chassis from any oxidation so you get a good electrical connection with the shield when you tighten down the chassis.You need to do this just before you install the chassis..Ben probably witnessed his amp being put in the cabinet. :D
hitchcaster
Post by hitchcaster »
what could he be measuring from the empty chassis from one side to another?
the "scrapping the whole build" after remeasuring at the end part had me confused though...
he's not BS'ing...
I think it has to be measuring across the ground points after cleaning the contact areas. Anodizing, BTW, is something that can be done at home.
Bombacaototal
Post by Bombacaototal »
This is the Tweed Glasswerks Cabinet Ben is using with the Lindley amp: http://www.glaswerks.com/GW112.htm
Small and compact 1 x 12 cabinet
13 Ply Baltic birch construction
Oval ported back
Bottom mounted amp glides for easy loading
Size : 16"H x 22"W x 12"D
modman
Post by modman »
hitchcaster wrote: Thu Oct 11, 2018 2:09 am what could he be measuring from the empty chassis from one side to another?
he's not BS'ing...
Of course Dumble is BS'ing -- now you heard first hand what a BS-er Dumble is
Why? Myths create dollars, especially in the 70s -80s -90s
In the internet era we should look beyond that.
