Rack stuff
Re: Rack stuff
JD0x0 wrote: Mon Mar 16, 2020 11:15 pm Any gut pics you're willing to share? I'm curious how the tubes are mounted.
I noted this above, I haven't made the boards yet. I know how I will be mounting the transformers. Through eyelets and I have the drill pattern so I can drill a blank G10 board.
The two 12AX7 tube sockets I mounted on a piece of aluminum angle which will be either rivoted or bolted to the chassis bottom and the tubes lay horizontal in the chassis, Photos will be upload when I coomplete the boards layout inside the chassis.
Re: Rack stuff
MakerDP wrote: Mon Mar 16, 2020 11:31 pm A little late adding transformer suggestions, but have you considered this replacement for a 6G15 reverb unit?
https://www.tubesandmore.com/products/t ... one-reverb
Very cool designs by the way!
I have used that transformer when I have 2 or more inches of clearance to work with.
In a 1 unit rack unit you don't have that room to work with so I have to go with a flat pack transformer.
Re: Rack stuff
Mark, I’ve done as you are thinking with the flat pack transformers. Insert eyelets from the back side of the board and solder the eight pins in. Most recently for this spring reverb project: https://ampgarage.com/forum/viewtopic.p ... 14#p395014
MakerDP
Re: Rack stuff
Post by MakerDP »
M Fowler wrote: Tue Mar 17, 2020 1:48 pm
Ah yes, of course... that small detail was totally lost on me... lol.
