Circuit Analysis Jim Kelley Amp
- FUCHSAUDIO
Re: Circuit Analysis Jim Kelley Amp
Sure. It was an active model for some time. Fender style input channels and 4 x 6V6's running at a blazing 500 volts.
It also had an outboard attenuator that allowed a master volume of sorts.
That’s my thoughts exactly Andy. Even though it has roughly 8K on the screen grids, it’s a hell of a lot of voltage on 6V6’s.FUCHSAUDIO wrote: ↑Sat Oct 29, 2022 2:37 pm Sure. It was an active model for some time. Fender style input channels and 4 x 6V6's running at a blazing 500 volts.
Personally, I’m wary as it relies of valves being above spec and very good quality control. I just don’t see that happening these days.
I would understand people rewiring it to a more sturdy valve.
I understand that he was after more brightness and greater dynamics, but the cost to the valves and reliability troubles me.
Having 2 Jim Kellys, I can say ,it‘s not a problem with JJ‘s.One has 470v, the other about 460v on the plates.
High Plate Voltages are not so much problematic,High Screen Voltages can be.
These are great amps!
- FUCHSAUDIO
6 others liked this
Jim Kelley is of the opinion that it's current that kills tubes, not voltage. I partially agree, but only if you roll back the screens a lot. In a Music Man, they used EL-34's and (later) 6L6's at 650 to 700 volts, but with the screens at half voltage and running about 20 ma a tube, and they lasted years. The current JJ 6V6's (rumored to be 6L6's in a smaller bottle) seem to hold up in the Kelly amps. There is a certain angry clarity of sound you can get from tubes getting beat-up at high voltage for sure....
Hello all. I've looked at different JK schematics but I cannot find power amp node B. Node A is plates and screens, node C is the PI, node D is V1 and V2. Any help please.Thank you.
- dorrisant
Welcome, Andrew!
The B node goes to the reverb driver...
https://ampgarage.com/forum/viewtopic.php?t=29580
Edit: I had already posted this on the previous page.
![Embarassed :oops:](./images/smilies/icon_redface.gif)
Thanks Dorissant .
