ODSR #13 Hand drawn layout by H.A.D
Re: ODSR #13 Hand drawn layout by H.A.D
Reverb > OD:
https://www.youtube.com/watch?v=oF5bz61SJu4
http://ampgarage.com/forum/viewtopic.ph ... 52#p188952
OD > Reverb:
https://www.youtube.com/watch?v=fMIJuuk1SFs
https://www.youtube.com/watch?v=LfBgrtPbxOg
Have a nice weekend!
Max
OD > Reverb:
Max
Got the impression that the one in the first post in this thread was created from the drawing. Is this not the case?
https://ampgarage.com/forum/viewtopic.php?f=4&t=22855
Phil
Tony, I had a look at your drawing in Photoshop... When I am working with old manuscripts, I find it is sometimes helpful to invert the image. Here is the inverted image:
Here's the drawing widened - yours appears to have a compressed width - probably a setting in the pdf output that was used.
Stephen
And to this, I also applied an unsharp mask. Too much and this puts a halo around the characters - it becomes unreadable in a different way! There are other sharpening strategies - high pass filters (of the visual kind) but there isn't enough resolution in the original image to work with. This is a little better, but when you zoom in to read those written values, it is heavily rasterised. Do you have a higher resolution copy of this drawing?Here's the drawing widened - yours appears to have a compressed width - probably a setting in the pdf output that was used.
Stephen
Stephen
www.primatone.eu
www.primatone.eu
I have 3 schematics here of supposedly #013. All a little different at first glance.philbard wrote: ↑Sat Mar 20, 2021 12:36 pmGot the impression that the one in the first post in this thread was created from the drawing. Is this not the case?
Aaron says
A quick glance at Aaron's schematic has a 100k mid pot and #13 is pretty clearly marked on the hand drawn 250KA (As is all 2nd generation amps)https://ampgarage.com/forum/download/fi ... &mode=view Perhaps he can comment? (BTW.Not meant to flame him Aaron does great work!!Thought I would have a go at tidying up the blurry hand drawn layout that is supposed to be ODRS #13, dated 8th August 76.
Circuit is not 100% confirmed. Some values that I couldn't make out I took from the 2nd Gen files.
I have not built or tested so assume it has errors.
If anybody knows or has seen this amp I would appreciate any input. Feel free to send me anything
I sharpened it a bit after adjusting the contrast to try to improve its readability, its a pretty crappy photo, low res, so sharpening beyond a small amount only makes things worse. A higher res version, if its out there anywhere would be better material to work on, even if its a bit soft. Or an image that isn't in jpg form though I suspect that's unlikely.talbany wrote: ↑Sat Mar 20, 2021 11:11 pm
Aaron saysA quick glance at Aaron's schematic has a 100k mid pot and #13 is pretty clearly marked on the hand drawn 250KA (As is all 2nd generation amps)https://ampgarage.com/forum/download/fi ... &mode=view Perhaps he can comment? (BTW.Not meant to flame him Aaron does great work!!Thought I would have a go at tidying up the blurry hand drawn layout that is supposed to be ODRS #13, dated 8th August 76.
If anybody knows or has seen this amp I would appreciate any input. Feel free to send me anything)
Phil
I agree Philphilbard wrote: ↑Sat Mar 20, 2021 11:52 pmI sharpened it a bit after adjusting the contrast to try to improve its readability, its a pretty crappy photo, low res, so sharpening beyond a small amount only makes things worse. A higher res version, if its out there anywhere would be better material to work on, even if its a bit soft. Or an image that isn't in jpg form though I suspect that's unlikely.talbany wrote: ↑Sat Mar 20, 2021 11:11 pm
Tony![]()
I tried Photoshopping this thing 10 ways to sunday to try and enhance it and in most cases only made things worse. Unless there is someone out there that has any better ideas or some kind of forensic software to make it readable? or some detailed shots..
I don't know? it was worth a shot!..Having looked at it for about an hour I can determine about half the layout.
Thanks!
Thanks Max
Erwin already posted this in the 2nd post however what amp is this?
https://ampgarage.com/forum/viewtopic.p ... 39#p294839
and do you know the serial # Judging by some of the components (Flexfoam/Mepcos TVA's say 77) it does look like a 2nd generation
So It looks like Aaron took bits and pieces from different Ser# ODSR's
BTW.Enjoyed the article on Bobby
Tony2nd generation Overdrive Reverb:
3 tubes (driver, return amp, mix amp,). Mix is done before the OD circuit. So you have ìoverdriven reverbî. By this the reverb gets the more prominent, the more the OD decays. It is a bit like with a Deluxe Reverb in power amp saturation mode. When the note decays, the reverb gets more prominent. These amps have less gain AFAIR than the usual 2nd generation ODS.
3rd generation Overdrive Reverb: No idea
4th generation Overdrive Reverb:
3 tubes (driver, return amp, mix amp). Reverb send is behind volume and ratio, mix before master volume. By this the reverb is a bit like an effect in the loop.
Hi guys,
The 100k was probably an over sight. The bulk of my schematics and layouts were done when I was working full time and only time I had to do them was late nights, there were many 2-3am nights!
Tony, doesn't SSS #005 have the "Tweed" mixer circuit, which is my favourite too!
Aaron
Aaron
Hi Max,Max wrote: ↑Sun Mar 21, 2021 12:59 am
http://www.antiqueamp.com/dumble/amporg.html
Max
I think those amps are OD-50WR #0030 and OD-100WR #0081. Both are pre OD.
Aaron
AaronAaron wrote: ↑Sun Mar 21, 2021 10:59 am Hi guys,
Aaron
Hello!. So just to be clear the bulk of the info obtained for your layout was from the hand drawn or was it from the 2nd generation Electron posted or did you use both?..Just trying to get an idea as to where you collected all your data,was it from 1 amp or several and did you embellish any along the way?.. Believe you me having done my fair share of these reversed engineered layouts Time consuming is an understatement and typos will happen!
![Wink :wink:](./images/smilies/icon_wink.gif)
From Electron
AFAIK Dumble used the "Tweed mixer" in SSS #002. (I built one) not sure about 05. I know it was not in 07 (Bruton-EJ) 004 and 002Serial is in the low 30s (sorry, can not tell you the serial right now).
I've often wondered given how well that mixing section works (transparent and controllable) he didn't eventually integrate it into his ODSR's...If i were to design one the T.M would be how i would try to do it. (After the OD
BTW. The tone reviews on 13 I have heard have been mixed? Did you build it and if so were you impressed?
Thanks!!
Hi Tony,talbany wrote: ↑Sun Mar 21, 2021 11:35 am Aaron
Hello!. So just to be clear the bulk of the info obtained for your layout was from the hand drawn or was it from the 2nd generation Electron posted or did you use both?..Just trying to get an idea as to where you collected all your data,was it from 1 amp or several and did you embellish any along the way?.. Believe you me having done my fair share of these reversed engineered layouts Time consuming is an understatement and typos will happen!![]()
From ElectronAFAIK Dumble used the "Tweed mixer" in SSS #002. (I built one) not sure about 05. I know it was not in 07 (Bruton-EJ) 004 and 002Serial is in the low 30s (sorry, can not tell you the serial right now).
I've often wondered given how well that mixing section works (transparent and controllable) he didn't eventually integrate it into his ODSR's...If i were to design one the T.M would be how i would try to do it. (After the OD) The other thing is go with either a straight Classic or Skyliner stack and not the one used in the 2nd gen amps..IMO
Thanks!!
The bulk of it was from the hand drawn layout, squinting as much as I could to try and make out most of the values.
It was unconfirmed and I mentioned if there was any errors let me know, no-one did until 8 years later
![Laughing :lol:](./images/smilies/icon_lol.gif)
I built an #0013, but the reverb can get lost with the overdrive channel. I prefer the post reverb circuit as in #0060. But then the reverb can get too much, depends on how you set the overdrive level. I would mind having a go at building something like #0137 with "clean" and "overdrive" reverb controls.
Do you refer to the SSS #002 as "Tweed" because the signals are from the cathodes? AKAIK SSS #001 and SSS #002 had the same mixer circuit, #004 is similar to this ODR #0013 and SSS #005 is from the wiper?
Aaron
Correct! Mixing is done at the cathode end or low impedance mixer. This generally requires an extra tube so your typical SSS (with trem) Reverb with Tweed mixer (4 tubes) and P.I Driver would be 8 total. Others were called 3 tube reverb'sDo you refer to the SSS #002 as "Tweed" because the signals are from the cathodes? AKAIK SSS #001 and SSS #002 had the same mixer circuit, #004 is similar to this ODR #0013 and SSS #005 is from the wiper?
#001 Keiser amp 8 tubes w/driver Mixer sec bottom right front #002 Schematic taken from hand drawn schematic from Japan 8 tubes Tweed Mixer #00? Commissioned by Ry Cooder (Snakeskin) Pentode amp (AFAIK) 3 tube reverb Tubes and their function 2xEF (input, recovery after EQ), 7247 (reverb mix), 7025 (reverb return), 12AX7 (tremolo), 5751 (reverb send), 7025 (phase inverter), 7025 (driver), 4 x 6550A. SSS #004 Keiser (six preamp tubes) No Tweed No Driver
SSS #005 Santana/Bruton (I believe this is also the one Brandon used for his High Planes Drifter) no Driver no Tweed During the early days the ser#'s on the SSS quite often got confused or were simply wrong..So if something is not right let me know and will correct it.
Thanks for the rundown on #0013. Sort of sounds like some of the other reviews I've been getting.
Thanks Aaron and Tony !
I wouldn’t mind the reverb disappearing on OD as long as it’s not over powering and washed out by the OD.
I guess 13 is a lower gain affair too as the clean is quite attenuated (like a JM) right at the output of V1b before the reverb stages.
How does it sound clean Aaron with that reverb and output stage compare to the others amps you build (SSS and the pentode amp for exemple) ?
I was thinking more about a clean with reverb amp with an additional OD rather than an ODS with reverb.
And btw do you have a favorite tank for those 3/4 tubes reverb ?
I’m a bit lost on reverb choice. Lately I use a classic Fender 2 springs like 4AB2A1B.
