Rocket build
gktamps
Re: Rocket build
Post by gktamps »
Source: ToneSlut
dvbme
Re: Rocket build
Post by dvbme »
You are awesome sir. I ended up watching Uncle Doug and the wires were,
Gray 5 ohms,
brown 5 CT 00.5,
yellow/green 37.4 CT 18.4,
yellow 42.1,
Black 01.6
dvbme
Re: Rocket build
Post by dvbme »
I got it running but it is clean and not breaking up.
gktamps
Re: Rocket build
Post by gktamps »
The Rocket is a pretty clean amp as designed. How is the volume? Have you made all of your voltage measurements and written them down on the voltage chart? If so, post that here.
dvbme
Re: Rocket build
Post by dvbme »
The screen is 263 the anode on 6-7 is 254 4-5 is 278
dvbme
Re: Rocket build
Post by dvbme »
I had rumble that turned out to be one of the 12ax7's.
Red plating changed 100 ohm 5w screen resistor to 470 5w solved it.
dvbme
Re: Rocket build
Post by dvbme »
It is very loud and clean. when crank it it only slightly breaks up. In the video I'm using a Maxon overdrive. Watching Glen Kuykendall and it's just screaming.
Even with the Maxon overdrive i can still hear 30% clean from the amp.
dvbme
Re: Rocket build
Post by dvbme »
gktamps wrote: Wed Apr 26, 2023 1:46 pm The Rocket is a pretty clean amp as designed. How is the volume? Have you made all of your voltage measurements and written them down on the voltage chart? If so, post that here.
The volume is like 10 but starting at 1. there is no chill between 0 and 1. at 1-2 sounds like 5 on my jcm900-100w but really clean.
dvbme
Re: Rocket build
Post by dvbme »
So there's no heaters.
V1 1 3 6 8 9
119 0.72 77 0.59 0
V2 1 2 3 4 9
187 108 108 0 0
V3 1 2 3 4 6
163 107 95 0 166
V4-5 3 4 7
8 0 292
V6-7 8 0 292
screen 288
GZ34 300
didit
Re: Rocket build
Post by didit »
dvbme wrote: Sun Apr 30, 2023 8:47 pm Watching Glen Kuykendall and it's just screaming.
Express, not Rocket, at least in all video I’ve screened.
dvbme
Re: Rocket build
Post by dvbme »
didit wrote: Tue May 02, 2023 3:16 pm
Although the rocket is warmer it still screams to a degree which this isn't and because the heaters have no volts i suspect that's why.
didit
Re: Rocket build
Post by didit »
dvbme wrote: Tue May 02, 2023 7:37 pm
Post video link?
LOUDthud
Re: Rocket build
Post by LOUDthud »
Isn't V2 a cold clipper ?
V2 1 2 3 4 9
187 108 108 0 0
Those Voltages don't seem right. Maybe the 10K from pin 3 to ground is wrong or missing. Maybe a short 2 to 3 and no 10K ?
FYI: AC Voltages should read zero on a meter set to DC Volts.
dvbme
Re: Rocket build
Post by dvbme »
LOUDthud wrote: Wed May 03, 2023 11:38 am Isn't V2 a cold clipper ?
V2 1 2 3 4 9
187 108 108 0 0
Was reading rob robinette what to measure on ac or dc with tubes out and picked up on a few things today.
Noted. will check.
dvbme
Re: Rocket build
Post by dvbme »
Volume is at 3 in the room it's as loud as the drum set.
