Effects loop for SV20ish amp
pdf64
Re: Effects loop for SV20ish amp
Post by pdf64 »
Was an input trimmer fitted?
If the supply voltage is too low and input signal too high, that or any circuit will clip.
Or the send signal may have been too high for some pedals to cope with.
statorvane
Post by statorvane »
Attached is the layout I developed.
If I were to do it again, I'd add true bypass to the loop (switch). As designed the loop is persistently in the signal path.
audiosalvage
Post by audiosalvage »
Thanks for the layout
