Musings on the State of the 5e3 Art in 2024
lonote
Re: Musings on the State of the 5e3 Art in 2024
Post by lonote »
pdf64 wrote: Wed Oct 16, 2024 2:42 pm It's unfortunate and regrettable that such an unsuitable material is the default board substrate used for builders of Fender type amps.
Agreed.
If I were to intentionally do a vintage layout AB763, etc. I would likely use eyelets, but there is GR10 glass board stock available in 1/16" thickness that would be far better suited & still look nearly correct.
lonote
Post by lonote »
Any way to physically float/isolate the junction of the B+ feed to the 100K plate resistors?
2tone
Post by 2tone »
I remember Ken Fischer telling me that the synthetic coating on modern push back wires could conduct stray voltages. I had a recent built amp with these and did measure several mv on the surface of these wires. Of course lots of old eyelet boards can at times conduct stray voltage..maybe it depends on the humidity?
psb962
Post by psb962 »
Update: I moved the 68k resistors to the jacks, wired each pair direct to the 12AY7 grids, and the DC has completely gone from all 4 inputs.
Problem solved. Thank you all!
psb962
Post by psb962 »
Next question I have to answer is whether to mod the tone control so that I can use it as a high cut without losing all the middle - and hence overdrive - that the standard tone control appears to do (due to its massive 4n7 capacitor).
This topic has been addressed both on the Robinette site https://robrobinette.com/5e3_Modificati ... _Cap_Value, and on Rondo's site (in great detail) http://www.recproaudio.com/diy_pro_audi ... ss_mod.htm.
I ran some simulations on LTspice using my model I posted and sure enough you can clearly see the tone control cutting highs and mids all the way down when the tone is below about 7. Replacing the 4n7 cap with a 680p cap appears to limit the high cut to 600Hz and up, which should be about right.
I overlooked this one when doing my build, but getting that overdrive while not having head sliced off by treble from a Jensen-like alnico speaker is important, right?
I would be grateful to hear from others who have tried this mod or have opinions about it.
psb962
Post by psb962 »
Ok, next topic - sag.
These amps are renowned for sag when pushed hard at high settings. Does this mean the B+ drops due to excessive current draw? Has anyone every measured that?
If the B+ drops significantly it might be cool to have some sort of mod which lit an LED when the B+ drops below a certain level.
St4rP0wd3r
Post by St4rP0wd3r »
Just built this amp as my first project ever. I decided to go full throttle on the diy and sorted 100% of the parts myself, without starting with any kit.
I also used a blank chassis as I really don't like the facing-up style chassis and wanted all toggles on the faceplate. I finished it literally 20 minutes ago, so I didn't have much chance to play it yet, but result and the easiness to build it surprised me.
LOUDthud
Post by LOUDthud »
Rock On !!!
psb962
Post by psb962 »
St4rP0wd3r wrote: Tue Oct 29, 2024 9:06 pm Just built this amp as my first project ever. I decided to go full throttle on the diy and sorted 100% of the parts myself, without starting with any kit.
I see you built in a bunch of mods from the start - like I did - with the screen resistors, rectifier diodes, filter cap bleed resistor, and power reduction. If it helps simplify things later on I find that having no standby switch works really well. Did you use separate cathode resistors and bypass caps on V1? I can't see any bridge across the cathode pins on V1.
