Outer Foil Test
- glasman
Re: Outer Foil Test
A couple of months ago I spoke with the sales manager at Sprague on OD's and Rohs. We got to taking about the polarity marks on old series PS caps. His comment was enlightening... "we are using the same equipment today that we used 25 years ago to make these caps and there is no way in hell those old markings meant anything as they never attempted to guarantee polarity".
I ccontinue my diligence today checking every cap I drop on a board..... its laborious, but adds that extra mojo......
Gary
Gary
About 5 miles south of I-94
www.glaswerks.com
www.glaswerks.com
- Funkalicousgroove
Re: Outer Foil Test
The Dumbles I have seen all seem to have the Marked side of the Cap toward the PT except for the .02 at the entrance of the PI, I wonder..........
- glasman
Re: Outer Foil Test
Not sure what you mean by PT. But they normally point towards the plates. On the PI, the low impedance side is on the input side. The grid side of the PI has an impedance of several megs due to the bootstraping of the PI.Funkalicousgroove wrote:The Dumbles I have seen all seem to have the Marked side of the Cap toward the PT except for the .02 at the entrance of the PI, I wonder..........
Gary
EDIT: Actually the grid side is probalby in the order of 20 to 40 meg. A DVM will load the heck out of the grid voltage.
www.glaswerks.com
www.glaswerks.com
Re: Outer Foil Test
I think we should start another internet myth that HAD threw away any cap that didn't have the foil connected to the right-hand side when looking at the marked side.Funkalicousgroove wrote:The Dumbles I have seen all seem to have the Marked side of the Cap toward the PT except for the .02 at the entrance of the PI, I wonder..........
FWIW, I once did a "spec" build that included measuring everything, using only components within close tolerances, orienting caps for polarity, etc. The result was no better than any other build I've done and in some aspects, not as good. On the cap issue, the Dumble design is pretty solid and not prone to pick up extraneous noise so you may or may not notice any difference.
Re: Outer Foil Test
80% of the PS caps in my last batch I tested had the 'foil side' on the lead to the left of the writing. Coincidence? I think not!Funkalicousgroove wrote:The Dumbles I have seen all seem to have the Marked side of the Cap toward the PT except for the .02 at the entrance of the PI, I wonder..........
Re: Outer Foil Test
They probably travel on a conveyor or something similar from production to printing if they do it all in one go, so there is a good chance they'll land the same way round, rather than a certainty that they keep track of the orientation.odourboy wrote:80% of the PS caps in my last batch I tested had the 'foil side' on the lead to the left of the writing. Coincidence? I think not!
Re: Outer Foil Test
Scott,
You misunderstood my post. I was testing for outer foil orientation and marking my caps...that's it. I had read long ago that the line didn't mean anything but I had never tested it myself. Now I have. Pretty simple.
Re: Outer Foil Test
J.B. Saunders. Boulder. Also good for connectors And miscellanyFunkalicousgroove wrote:Where is a good place to get ground clips for probes? My scope is so old and I need some new clips, Mine are hangin on for dear life!!
Give Outrage back to the Outrageous !!
Re: Outer Foil Test
Isn't there another way to test for this? I remember reading about using aluminum (aluminium, lol) foil, the outer casing, certain lead connections, and a good VOM, but just cannot find it again. No OScope yet for meFischerman wrote:I also learned to not disconnect the negative lead of the scope until I marked the cap...too easy to disconnect the leads and then think; "Wait...which side was outer foil again?". But if you're not as fry-brained as me you could get away with it.
Lastly, my scope probe has a clip for the negative but just a point for the positive. Connecting a short wire with alligator clips on each end to the point (to make it easier to clip both + and - leads to the cap) was a deal-breaker. Tons of extra noise. Need to get a 'clip tip' for that probe.
Re: Outer Foil Test
If your VOM does capacitance you can put some foil around the cap and with the + lead on the foil move the - lead to find the lead that gives the biggest capacitance reading. Mark that lead as the shield.
www.RedPlateAmps.com
Re: Outer Foil Test
Guy's, I love this thread, Great Read, but, take the cover off the orange drop and you look at the way the wire is attached on each end of the roll of foil and then tell me what you think about "POLARITY"
Johnhenry
Johnhenry
Re: Outer Foil Test
Thanks, that's the one!heisthl wrote:If your VOM does capacitance you can put some foil around the cap and with the + lead on the foil move the - lead to find the lead that gives the biggest capacitance reading. Mark that lead as the shield.
Re: Outer Foil Test
The .1uF caps I tested had very little noise but some of the smaller value ones had way more. In any case, what you see on the scope will tell you for sure whether it's there and how much.Guy's, I love this thread, Great Read, but, take the cover off the orange drop and you look at the way the wire is attached on each end of the roll of foil and then tell me what you think about "POLARITY"
- Funkalicousgroove
Re: Outer Foil Test
Been there, they didn't have any, but they did have a good selection of stuff nobody else wants!!Chicken Head Red wrote:J.B. Saunders. Boulder. Also good for connectors And miscellanyFunkalicousgroove wrote:Where is a good place to get ground clips for probes? My scope is so old and I need some new clips, Mine are hangin on for dear life!!
It's actually a really cool store, I spent like 3hrs there!
- glasman
Re: Outer Foil Test
Try www.circuitspecialists.com
They have a good selection of the right stuff. It is where I buy a lot of test leads and things.
Gary
Gary
www.glaswerks.com
www.glaswerks.com
