point to point D-lator build in hammond rack chassis
Funkalicousgroove
Re: point to point D-lator build in hammond rack chassis
Post by Funkalicousgroove »
I just copied the original as closeley as possible without using PCB's.
The tube is mounted as the original, and it is plenty snug. Since it is rack-mounted and not subject to cabinet vibrations it should be just fine.
Funkalicousgroove
Here's the original
Funkalicousgroove
Here's the original
Funkalicousgroove
here is the power supply
gearhead
Post by gearhead »
Yeah! Funk is da MAN!
tomrasdf
Post by tomrasdf »
where do you get those wonderful toys.
"In this world you will find hardship and trials; but take heart, for I have conqured the world."
John 16:33
heisthl
Post by heisthl »
Thanks a million for posting this - very helpful
www.RedPlateAmps.com
Funkalicousgroove
Sure thing!
kleinm
Post by kleinm »
Wooo! Thanks for this Brandon!
WOOOOOOOOO!!!!!!!!!!!!!!
67:1
resophonic1
Post by resophonic1 »
Brandon,
Thanks for sharing your build and the additional info!
Tdale
Post by Tdale »
What kind of shielded wire do you use? And can you notice any change in sound (less highs)?
Tommy
Funkalicousgroove
I use an ultra low capacitance cable (11pf/ft) and it has "more highs" than the typical RG180 type cable.
Tdale
Post by Tdale »
where do you buy it?
Tommy
Funkalicousgroove
How much do you need? I have a 1000ft roll I can break you off some or you can get your own roll from www.gepco.com it's the digital audio cable. 2 conductor, 24awg.
zephyrblau
Post by zephyrblau »
Funkalicousgroove wrote: www.gepco.com it's the digital audio cable. 2 conductor, 24awg.
DS401 ?
