A Collection of #124 Information (Schematics, Layout, etc.)
rfrakes331k
Re: A Collection of #124 Information (Schematics, Layout, etc.)
Post by rfrakes331k »
Can I get similar sounds out of a D Lite if I were to build one of those comparing the D Lite to the ODS 124?
ic-racer
Post by ic-racer »
rfrakes331k wrote:Can I get similar sounds out of a D Lite if I were to build one of those comparing the D Lite to the ODS 124?
If you copy the #124 power supply and output section (ie four 6L6) then maybe it would be close. There is a lot of experience on these boards tweaking D Lites, but I don't think they wind up with values similar to #124.
Yes, quite a difference from two to four 6L6 tubes warmed up. :D
lexluthier
Post by lexluthier »
Dumb question, but is there a bill of materials list for someone who wants to build a #124 clone? I was going to go through the schematic and write it all down, but if there is a list that would be great. I tried the search function but there were so many results I couldn't find it.
Dave
ic-racer
Post by ic-racer »
I don't think there is an exact #124 BOM, because it may not be of that much use, as there are many unobtainable parts. I built mine from the pictures and scattered notes.
There are, however, a number of similar BOM's out there.
In case you have trouble finding them, I have attached one. It is not accurate to #124, but it is similar and it could serve as a good starting point (ie check it against the schematic).
lexluthier
Thanks! :D
Dave P
collinsamps
Post by collinsamps »
Great stuff for us newbies ic-racer, thanks.
ampman1961
Post by ampman1961 »
Wow...
I never thought I would get so much mileage out of those pics when I de-gooped 124, and Gil took the pictures. Amazing. I had a visit with 124 recently and retubed her...sounds very nice. Keep up the good work guys.
Billy Yates
"Life is too short for Solid State"
www.redjonesamplification.com
No thank you Billy.
The photos and details were priceless.
ChrisM
Post by ChrisM »
Comparing the layout to schem. Seems there is a mixup maybe with the ratio/level pots. They are reversed on the layout/schem. Shouldn't the ratio be first in the signal path then level? Also the values and tapers done correspond.
EDIT: Also the schem shows the FET section getting power from B+5 while I see on the layout it getting it from B+ 4. I am reading this wrong?
odourboy
Post by odourboy »
ChrisM wrote:Comparing the layout to schem. Seems there is a mixup maybe with the ratio/level pots. They are reversed on the layout/schem. Shouldn't the ratio be first in the signal path then level? Also the values and tapers done correspond.
Hmmm... Agreed. Seems to me the labels on the 'Level' and 'Ratio' pots got switched. The FET board power is messed up also - swapping the cap+ and V1 plate wires with the V2 plate wire on the terminal strip lugs would straighten this out I think.
ic-racer
Post by ic-racer »
Good pickup. I don't have the original Layout file, otherwise, I'd change it.
ChrisM
Post by ChrisM »
Can the current one be edit, or does anyone else have the original?
David Root
ODS Pot Mix-Up
Post by David Root »
I'm still trying to get this straight in my mind.
1) Ratio pot precedes Level pot, yes/no?
2) Ratio pot is 100K Lin, yes?
3) Level pot is 250 K Lin, yes? (Or audio taper if you prefer).
David Root
ODS Pot Mix-Up
