Equivalent for NTE 452
glasman
Re: Equivalent for NTE 452
Post by glasman »
martin manning wrote:
glasman wrote:Naw, the idea is a good one but the d-pre is not a great bit of engineering. I really like what adding 10 to 15dB of gain on the front end does for single pickups. The second sucky side of it is a phase inversion, but that is fixable as well.
What is the disadvantage of the phase inversion? Seems like it wouldn't matter unless there is some parallel device in use, or the amp were configured to use both inputs.
MPM
There are a lot of guitarists that are "into" the concept of absolute phase. In other words, if the signal is going positive on the input to the amp it should be going positive at the speaker and that the speaker cone should be pushing out. I have to admit, you can hear a little bit it difference (using a reverse cable to the speaker).
Gary
About 5 miles south of I-94
www.glaswerks.com
FUCHSAUDIO
Phase inversion
Post by FUCHSAUDIO »
I agree, a little bit of boost in front is a good thing...especially with single coils :). The phase inversion is a benefit, as you don't need to reverse any speaker wires to be back in phase, especially if you have an inverting loop.
sergio
Post by sergio »
Thanks all for your helps
Sergio
engelheimer
Post by engelheimer »
The first time I had a guitar amp come in with FET's was a Webb 6-14E. It had a PF5103 on the input and the 2N5949 on the reverb in and stage after the tone stack. Was in the 70's when I opened the shop here in Central Texas, remember the FET was a new kind of transistor and this one was for RF, it had the detail found only in a tube back then. The ones now have low noise and capacitance, are easy to find...
Geö
Stephen1966
Post by Stephen1966 »
sergio wrote: Fri Feb 27, 2009 1:37 pm Hi , there are a good equivalent for NTE 452 JFET?
For me is difficult search the original in Europe...
Thanks all.
Sergio Italy..
https://www.tme.eu/cz/en/details/nte452 ... ctronics/
Stephen
www.primatone.eu
sergio
Post by sergio »
Thanks very much
www.sae-audio.it
Handmade tube amplifiers inspired to Dumble sound!
2N4416A is fine for the FET boost.
Smitty
Post by Smitty »
martin manning wrote: Fri Dec 02, 2022 3:10 pm 2N4416A is fine for the FET boost.
Thanks, Martin. I grabbed a handful of these:
https://www.ebay.com/itm/125249404667
