New ReleaSSSes
Re: New ReleaSSSes
It would be just like him to throw an inductor in just to mess with cloners. :lol:
ToneMerc
Re: New ReleaSSSes
Post by ToneMerc »
Structo wrote:It would be just like him to throw an inductor in just to mess with cloners. :lol:
Get it right..............."Bootleggers" :lol:
TM
Re: New ReleaSSSes
My SSS chassis #004 style was already drilled for board over the preamp tubes so PTP is the way I am going.
Here is what I have come up with so far, which may change :lol:
Rev1 for reverb added.
Not sure about PI and Driver.
Or for those with tubes all in a row and want one large board it gets wild figuring out the best component layout to use. lol:
FUCHSAUDIO
Re: New ReleaSSSes
Post by FUCHSAUDIO »
TM
Some are (proudly) "pure evil incarnate" :wink: :wink:
dcribbs1412
Re: New ReleaSSSes
Post by dcribbs1412 »
M Fowler wrote:My SSS chassis was already drilled for board over the preamp tubes so PTP is the way I am going.
Nice job Mark
Looks great
Darin
Re: New ReleaSSSes
Darin I just need to build it and then come back with corrected versions I'm sure.
I'm going to build the power amp first using the power amp in jack. Then get the pre-amp done.
Wish me luck. :lol:
dcribbs1412
Re: New ReleaSSSes
M Fowler wrote:Darin I just need to build it and then come back with corrected versions I'm sure.
Wish me luck. :lol:
I believe you will get it...
I'm sure the tweaking will be fun also.
Darin
mhartman
Re: New ReleaSSSes
Post by mhartman »
Wish me luck. :lol:
Looks great Mark. I'm looking forward to seeing your progress.
groovtubin
SOund clips
Post by groovtubin »
David Root wrote:I used a Fasel yellow inductor. Measures between 0.6 and 0.7 H on my LCR meter, depending on the frequency used. (120Hz & 1 KHz)
Any sound clips of your amp?? Be fun to take a listen!
jim
bigwebb83
soundclips from ceriatone SSS
Post by bigwebb83 »
Here are a few soundclips from my SSS. Still learning the amp but really loving it. These are with an alex attenuator. The first clip is with a King of tone as a clean boost, an Analogman Comprossor, and a timeline in the loop. Second clip has timeline in loop as well. I'm switching back and forth between an Aluminum Falcon and a Monsterpiece Stud to illustrate differences (I start with the AF on and then yell in the background everytime I change). The third Clip is just some random noodling with the aluminum falcon and a grosh strat.
http://soundcloud.com/bigwebb83/ceriato ... dling-with
http://soundcloud.com/bigwebb83/aluminum-falcon-vs
http://soundcloud.com/bigwebb83/ceriato ... ing-with-1
groovtubin
Re: soundclips from ceriatone SSS
bigwebb83 wrote:Here are a few soundclips from my SSS. Still learning the amp but really loving it. These are with an alex attenuator. The first clip is with a King of tone as a clean boost, an Analogman Comprossor, and a timeline in the loop. Second clip has timeline in loop as well. I'm switching back and forth between an Aluminum Falcon and a Monsterpiece Stud to illustrate differences (I start with the AF on and then yell in the background everytime I change). The third Clip is just some random noodling with the aluminum falcon and a grosh strat.
pretty close to the kaiser SSS where Doppler is a playing it! Throw a eric johnson fuzz and a tube screamer in front of it, and let us hear that! ;)
Re: New ReleaSSSes
Bigwebb do you have a clip with the amp cranked more so I can hear it distort or lead runs?
bigwebb83
Re: New ReleaSSSes
Post by bigwebb83 »
The preamp is at 2 o'clock and the master is around noon on most of those. I suppose I could dime it with the attenuator tonight and make a clip. With the attenuator fully involved though it does stiffle the clarity a tad.
bigwebb83
Post by bigwebb83 »
I love that clip. I'll post one later with a tube screamer in front. Oddly enough the high end TS808HW doesn't have enough grind to get the sound that doug was getting on that clip. Wish I had a REAL 808. My Keeley Reissue will have to do.
groovtubin
I`ve converted a quad reverb, single channel, cath follower reverb mix set, and done that, it is INSANE, really close to EJ`s stuff!! PM me, may have something for you! ;)
jim
