Tweed Overdrive Special
Re: Tweed Overdrive Special
Mat,
I don't anything about EF86 tubes. Never used one or even played an amp with one as far as I know?
I only have one overdrive pedal I use into the input and it sounds good with the amp. I use a Boss digital delay in the passive effects loop and really like the tone I get ALOT. I use the delay sitting in with the band always.
Having said that, I have relay switching & honestly I don't really feel an overdrive pedal is needed for what I am wanting to play.
With respect, 10thtx
Ok, I found a Philips EH86 datasheet from '70's that helped for the answer.10thTx wrote:Mat,
G1=control grid, G2=screen grid and G3=suppressor grid.
The pedal question was mainly for my interest of germanium fuzzes. I can hear the potential of the TOD from the clips and believe I will need no overdrive pedals in there but I like sometime to use fuzzes while playing. They interact nicely with guitars volume pot.
Thanks,
mat
Ok, I finally got time and changed my 50w dumble preamp into Tweed over drive special and am enjoying the result very much. I built it first with Svetlana EF86 (no 5879's where I live). Today I got the 5879's I ordered and rewired the socket. The sound is eaven better to me now. 5879 seems to give a meatier, little softer sound. EF86 is tighter but not what I was after. The D style power amp is quite stiff. I might try something other for the poweramp section. The amp has built in dumbleator and two relays controlled by footswitch (have to decide for what purpose is the other relay going to be).
I did two dry clips with EF86 and 5879 with same settings on both recordings. The playing comes from Boss loop pedal so they are identical. Everything else is the same but the tubes (and socket wiring). The EF86 has more gain and the clip was louder so I normalized both clips to have same volume. Not big difference but hearable for sure. I like the playing feel of the 5879 also more.
The EF86:http://soundclick.com/share?songid=9701368
The 5879http://soundclick.com/share?songid=9701371
38.5 celsius funk:http://soundclick.com/share?songid=9701309
Big Thanks for tubenit and Geezer for the great amp design !
mat
Absolutely wonderful playing and tone! Fantastic.
Thanks for sharing your success.
Thank YOU Jeff ! This is a really great amp design10thTx wrote:Absolutely wonderful playing and tone! Fantastic.
mat
To the guys who have built a Tweed OD Special...Do you think putting Sozo Blue Molded caps in this amp would offer a significant improvement on tone?
Sorry, I have no experience with Sozo Blue Molded caps..mcrracer wrote:To the guys who have built a Tweed OD Special...Do you think putting Sozo Blue Molded caps in this amp would offer a significant improvement on tone?
mat
I'm sorry I cannot comment on the TODS, but racer FWIW I recently built a jazz amp using Sozo Blue Moldeds throughout and they sound fantastic. Very clean, warm, and slightly dark sounding. The owner reports a "glow" on the edge of each note.mcrracer wrote:To the guys who have built a Tweed OD Special...Do you think putting Sozo Blue Molded caps in this amp would offer a significant improvement on tone?
Mat that sounds great!
Liked the last cut were you let it rip.
You have a great amp there.
Thanks Colossal, That's good news. I kinda thought that in a Tweed they might just sound good. I guess it will be up to me to do it. Adding another amp to the "list"
Here you can see those Sozo blue mold caps colossal used in his fantastic Gibson EH150 build nice work on this amp.
http://ampgarage.com/forum/viewtopic.ph ... c&start=15
Beautiful work!
Thanks TomStructo wrote:Mat that sounds great!
mat
Well, is that fever contagious and can I have some please?The fever I'm suffering might have caused a 'few' strange note selections
10thtx
A local builder has done a couple of "DC/30"-ish amps (Barwatt, and the amp is the Kingsnake) that along with a couple other mods uses a 5879 in place of the EF86 - reasons quoted being more manageable levels of gain, lower price, easier availability, and less inclined to be microphonics.mat wrote:Thanks for the answers. Guytron seems to use two EL84's on the preamp section: http://www.amptone.com/guytrongt100.htm
The reason for asking if the EL84 would do is that the 5879 is not so easily found in this part of the world I live. The delivery will be about 3-9 weeks from USA.
EF86 is more easily available and JJ's EF806S are on production today. Have anyone tried the JJ or would that be suitable for the TOD ?
Thanks,
__________________________________________
Cheers and Beers.
Cheers and Beers.
